EMT-built Thorens TD150 'table, with a whole host of modifications and improvements: * Uprated capacitors and closer-tolerance resistors in the power supply circuit. Better internal wiring. * High quality mains cable fitted. * Damping applied to plinth, sub-chassis and top-plate. * Motor modified to reduce vibration * New belt fitted * New multi-layer Rega drilled armboard fitted * Mat replaced * Linn Nirvana springs fitted * Corner bracing and plinth bracing fitted Many hours of work have been spent on this TT, and the end result sounds very good! It comes without a tonearm fitted, but with an RB250 fitted this will blow a Planar 2/3 into the dust for less money! Photographs available Asking £100 Simon simonconnell at hotmail dot com
