Monitor Audio R152 Full Specification Needed...
Discussion in 'Hi-Fi and General Audio' started by lga775, Feb 22, 2009.
  1. lga775
    lga775
    Feb 4, 2009
    6
    Your Contribution Is Appreciated.. Thanks.
  2. lga775
    shrink
    Apr 22, 2004
    1,255
    heres the specs for the R352... perhaps some of your components are similar, and may allow you to work out what your dealing with.
    MONITOR AUDIO R352
    Bass reflex.
    8" woofer
    1" dome tweeter
    Anechoic frqquency response 50Hz-20kHz +/- 3dB
    91 dB SPL 1w/1m
    20w rec. min. power
    8 phm nominal impedance
    Dimensions 25"x10"x13"
    Weight 29lbs
    $559US/pr
    shrink, Feb 22, 2009
  3. lga775
    lga775
    Feb 4, 2009
    6
    thank you for ur information
    thanks for ur information and i appreciate it. but it is not correct.
  4. lga775
    shrink
    Apr 22, 2004
    1,255
    like i said.. its for a different model... make of it what you will.
    your dealing with a speaker thats at least 20 years old now, its going to be hard to find exact specs for them without some hunting.
    try google ;) its what the rest of us use
