Had a really good play with my 2496 this weekend. In short, I've been too much of a cheapskate to get myself one of their ECM8000 mics, meaning that I couldn't really use the unit as anything more than a DAC. As my Bel Canto DAC2 pretty much walked all over it, just been gathering dust for a few months. Either way, Zanash was here with not only an ECM8000, but also a suitably long lead, so it was time to finally have a good play. Following some of Tensons advise, we upped the buffer and tried to avoid massive changes from the room correction. In practice we found that my room had a gentle suckout of upper frequencies, but a MASSIVE 18db hump at around 40hz. We tried a manual override at 40hz, and let the system do the job automatically for upper frequencies. Certainly changed the sound of things, though after some interesting comparisons with the Behringer in an out of circuit, I came to the conclusion that it did seem to be making a bit of a mash of the mid range, creating a very "flat" and dead sound. So, plan B. This was to ignore the automatic correction and simply go for manual correction of -15db at 40hz. The 2496 was sat in between my transport and DAC. Have to say that this seemed to minimise the "damage" caused by the correction, whilst still eliminating almost all of the bass "hump" in my room. Going forward, I see my using the 2496 to spot room issues in my next house, then trying to resolve the problems using bass traps and the like.
