more sub bargains
Discussion in 'Classified Adverts' started by Rory, Sep 25, 2004.
  1. Rory
    Rory satisfied
    1,084
    Ipswich
    Rory, Sep 25, 2004
  2. Rory
    djdstone
    Dec 11, 2003
    248
    LONDON
    Subs
    Does any one own one of these? How does it compare to the MJ 50? It does look very similar.
    djdstone, Sep 26, 2004
  3. Rory
    Rory satisfied
    1,084
    Ipswich
    bearing in mind bk elec make 95% of subwoofer amps they more than likely have identical internal amps and the drive unit looks identical too
    Rory, Sep 26, 2004
  4. Rory
    Graham C
    680
    Leicestershire
    Well, lets just say that when I bought a large order from them last year - it came in a cardboard box with 'MJ acoustics' on it!
    Graham C, Sep 26, 2004
  5. Rory
    Rory satisfied
    1,084
    Ipswich
    yes, ruark and mj acoustics appear to make the cabinets
    rest seems to come from bk electronics. the back of that vita 50 is identical to the back of a mj pro 50
    and the pro50 is a storming sub, especially for small rooms parterning standmount speakers
    Rory, Sep 26, 2004
  6. Rory
    djdstone
    Dec 11, 2003
    248
    LONDON
    Very interesting! I wanted to see want is sounded like with my Monitor Audio Studio 20SE's.
  7. Rory
    Rory satisfied
    1,084
    Ipswich
    you'll definetly want the vita100 if you have the studio 20se's
    they go down to 30hz or so anyway
    Rory, Sep 26, 2004
  8. Rory
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    BK electronics are the OEM for both MJ and REL.
    I-S, Sep 26, 2004
  9. Rory
    mr cat Member of the month
    Jul 31, 2003
    3,375
    5
    mr cat, Sep 27, 2004
  10. Rory
    Rory satisfied
    1,084
    Ipswich
    so why do u have an Eltax if it wasn't worth buying?
    Rory, Sep 27, 2004
  11. Rory
    Jul 31, 2003
    3,375
    5
    ooooohhh!!! as you'll read else where I'm in the process of upgrading all of my speakers (having just bought some kef Q4s, and are seeling my Eltax's... - but judging by your attitude the Q4's probably won't be good enough! :D )
    and when I replace my centre speaker (funds allowing) I will buy the SVS...
    some people....sigh... :rolleyes:
  12. Rory
    djdstone
    Dec 11, 2003
    248
    LONDON
    …exactly! No need to start bitching about what people have and haven't got.
    Back to the topic - does these deals sell out pretty quickly?
    djdstone, Sep 27, 2004
  13. Rory
    djdstone
    Dec 11, 2003
    248
    LONDON
  14. Rory
    avanzato
    Sep 20, 2003
    260
    The BK XLS200 has a good reputation on AVforums for performing well above it's relatively small price tag. Ths SVS is as yet an unknown quantity as no-one AFAIK has got one, past experience would say it'll be good but....
    Also that SVS has only one phono input, no high level inputs and no built in low pass crossover so not much use in a Music system, it needs an amp/processor with bass management.
    The BK deals do usually sell out quickly, but the XLS200 is a 'stock' item though sometimes there is a waiting list.
    avanzato, Sep 27, 2004
  15. Rory
    MartinC Trainee tea boy
    Aug 27, 2003
    995
    Southampton
    Well spotted, that's an extremely good point!
    MartinC, Sep 27, 2004
  16. Rory
    Rory satisfied
    1,084
    Ipswich
    never heard them.
    i sold the eltax atomic 12" sub at work actually, and it wasn't too bad.
    the BK xls200 is apparently on par with a REL Q200 performance wise and as someone pointed out, its a regular stock item. Those Ruark Vita subs will sell quickly. I'm tempted to buy a Vita 50 as i'm in student accomodation at the moment and not sure where i'm going to put my Logrhythm when i bring my hifi up @ half term
    Rory, Sep 27, 2004
  17. Rory
    djdstone
    Dec 11, 2003
    248
    LONDON
    As i understood it (and excuse me for my ignorance) I can run a line level output from my pre (which has two pre-outs) to the line level input on the sub and then adjust the crossover point to get it sounding right??
  18. Rory
    Rory satisfied
    1,084
    Ipswich
    djdstone-- yes , thats how i do it too. Run a stereo pair of RCAs from stereo preouts of my Plinius amp into stereo line ins on the subwoofer. I personally set crossover point to minimum (40hz on my Ruark iirc) and volume to just over half.
    Rory, Sep 27, 2004
    #18
  19. Rory
    djdstone
    Dec 11, 2003
    248
    LONDON
    Thanks Rory - I'm running mine of a rebuilt Sansui CA2000 preamp - fantastic pre-amp from 1979.
    #19
  20. Rory
    Rory satisfied
    1,084
    Ipswich
    bearing in mind you'll need 2 sets of pre outs. 1 set to go to your power amp and 1 set to the sub.... the sub doesn't have line ins and outs
    Rory, Sep 27, 2004
    #20
