Right, loads of bits up for sale in my clear-out... Many of these are my singlespeed which is being broken up for parts. Post is fine for smaller parts, but prefer collection in huddersfield or oldham areas for larger bits like frame, forks and wheels. Items are numbered, so for clarity please let me know which item nos you are interested in. Prices don't include post. Multi-part offers welcomed, photos available on request. 1) '95 Marin Nail Trail 19" alu frame. Well used. Comes with FSA Orbit headset and seat clamp and marin lite post. Perfect chainstay length for singlespeed - 32/18 does not need a tensioner £30 2) Onza Fly Guy XC Rigid forks with Magura 4-bolt and IS disc mounts. Very little use, excellent condition. Very light weight, very long steerer (at least 9"), 1 1/8th. £60 3) RST Mozo Pro W 3.5" forks. These are not the el-cheap ones, but the high end fork they did around '96 or 97... machined easton aluminium legs and coated alu stanchions. Fitted with yellow (soft or med - were always too stiff for me at 55-60kg) spring one leg (and the other will come with it) and a custom stack of soft elastomer and soft manitou spring in other leg. Some sort of pneumatic damping system. Anodised leg graphics (not stickers). 1 1/8th steerer, about 7". £25 4) Front wheel: Goldtec XC front hub (blue), DT 2.0mm PG spokes, Mavic D521. £30 5) Rear wheel: Truvativ Sealex rear hub (8sp), DT PG 2.0mm spokes, Mavic 121 £15 7) SS conversion kit for cassette hub. 16t and 18t (I think) sprockets if I can find both. £7 8) Deore Thumbies! 7/8sp (there's a "hidden" 8th index position, or you can put it in friction mode). £20 9) Retrotastic unexploded SRAM ESP900 8sp shifters (the transparent plastic housing first generation ESP). Couple of spare sets of grips (including purple sharkteeth, for that ultra-retro look). £20 10) First generation ESP 9.0 rear mech. Silver (alloy) and carbon print. £10 11) Second generation ESP 9.0 rear mech. Dark Grey. £10 12) Magura Raceline D HS22 brakes - last gen HS22s with the long lever blade but with red pad adjust dial. Braided hoses (both from lever to slave and also slave-slave). Evo and 4 bolt mount kits. Green and black pad sets. Spares from HS33 work fine (slave cylinders are the same... 33 has different master/lever. Hoses also interchangable). £25 13) Magura Horseshoe DH booster for Evo mount. £5 14) Magura Horseshoe DH booster for Evo mount. £5 15) Bright red Club Roost IDB150 flat bars, with red WTB dual-compound grips with very little use. £7 16) Ameoba CNC "Handwork" Stem. Think it's about 90mm. 25.4 clamp. 3 bolt faceplate. £5 17) XT M750 topswing front mech, plus second bent one for spares. £10 19) Acor red anodised bar ends. £5 21) Controltech in-line alu seatpost 31.6 diameter, ~350mm length. £10 22) two-cog singlespeed chain tension, derailleur type mounting - unused. £5 23) X-lite Disco BB bar plugs (stop apple-coring!) in "platinum" finish (similar to hope Gunmetal) - some scuffing. £7 24) 18 256mm DT 2.0/1.8 Competition spokes, stainless, with nipples, new unused - £5 25) 18 258mm DT 2.0/1.8 Competition spokes, stainless, with nipples, new unused - £5 26) Zoom suspension seatpost 26.8 with collars. £5 Missing numbers have already been sold...
