I bought a shed nearly a month ago and one month later I have had mixed feeling swith it so here goes:- I love the way it drives, the engine is very torquy and it is more than fast enough to get out of trouble in towns, I don't do motorway driving so higher speed is not an issue. Gearbox is very slick, clutch seems ok. It has burnt no oil, lost no brake fluid and lost no water, there is no no smoke at all from the back even when cold you just see a little condensation puff. There is a little buzz coming from the fuel intake area, it is an electrical sound, but when it makes this noise there is no difference in the way the car drivers, I am guessing it could be an iffy injector but either way this will be a cheap fix. The drivers door does not work and the door card is off atm ready for taking into the garage to get this fixed. I am also going to put new brake pads put on and the new arch brake pipes as these are rusting I want to change it to be on the safe side. I am going to get the brake pipes done ASAP as I don't want to be told at MOT time car wasn't safe to drive. It seems this car is in a lot better mechanical condition than my last one, but it does need some TLC. The way I look at it any sub £1k car this size will need work it is worth spending £200 to fix it.
