Myryad MXC6000 silver £895
Discussion in 'Trade Adverts and Discussion' started by Audiologica, Aug 17, 2010.
  1. Audiologica
    Audiologica Audiologica Ltd
    Feb 12, 2009
    631
    New and sealed, end-of-line stock, RRP £1400 - one only silver finish
    The Myryad MXC6000 Compact Disc Player has been designed to offer a combination of high quality sound reproduction and elegant styling in keeping with other Myryad products. The MXC6000 is a fullÂ*function remoteÂ* controlled CD player. It has fixedÂ*level lowÂ*impedance audio outputs to drive a Myryad integrated amplifier or preÂ*amplifier Â* or other high quality amplifier. In addition it has a digital output on a single RCA phono socket (SPDIF standard), suitable for driving a separate DAC (DigitalÂ*toÂ*AnalogueÂ*Converter), and a Smart MyÂ*Link® control input and output.
    * Digital-Analogue Converter 24-bit 192kHz delta-sigma with Dynamic Element Matching and dual differential outputs
    * Regulated power supplies Fourteen, each purpose designed
    * Audio Filter op-amps Two single high speed low-noise Difet types
    * Audio output DC-coupled, individually trimmed
    * Frequency response (20Hz-20kHz) ±0.2dB
    * THD (1kHz) 0.0018%
    * Signal/Noise ratio (A-weighted) 112dB
    * Output level at 0dB 2.3Vrms
    * Digital output Coax 75 to SPDIF std
