Hello, First off, I know there are several cable threads on those forums. I have read them, but felt they didn't answer my question. I have a marantz PM8000 amplifier, connected to two cabasse MT30 alderney tower loudspeakers. I've always considered it a very good soundsystem, in the sens that I was always very happy with it. I have moved house and my furniture has been re-organised. As a result, I now need ~25 metres of cable to connect the loudspeakers to the amplifier. My question is, which cable diameter should I use? The loudspeakers were previously connected using ~6 metres of 1 mm, standard, no-name cable. I never made comparisons between different cables, and was happy with the sound I got then. Now, the length I need has been multiplied by 4, and I surmise it calls for thicker cables, but I'm not sure which diametre to choose... I asked where I bought the amplifier, and was told that 4 mm is what is needed; the problem is price (15 euros/ m in this shop), I don't want to spend several hundreds on cables. I would therefore like your advice on some cheap, yet good cables. Thanks in advance, Cheers, alg
