I'm debating whether to replace my venerable old Ditton 66/2s - not because they're ancient and duff but because I'm worried about parts availability should they go bang... The only problem is I like bass - the Dittons go down (according to their specs) to 18Hz; most modern speakers seem to have at the very largest a 10" driver, which isn't necessarily enough to move the quantity of air I need moving as I also like it very loud. Which leads to the next problem - power handling.. I want to be able to run at a constant 1/2 volume for long periods with my Lumley 120s. I nearly blew a pair of Lumley Lampros 200 when demoing my cd player - had to continue on the Lampros 2000 which had the bass weight (plus 11 drivers!), but a price tag much more than double the £5k I'd be willing to spend, new or 2nd hand. Voicing-wise, I'd prefer something a bit BBC to go with the mega-bass - Harbeth 5 perhaps but with more bottom end? Oh, and they have to be handsome looking, though imaging/thwack/oomph and non-tiring pzazz are at the top of the list. Or should I just stick with the Dittons and be done with it?
