NEW SVS PB1000 £499 at Audiologica
Discussion in 'Trade Adverts and Discussion' started by Audiologica, Dec 18, 2012.
  1. Audiologica
    Audiologica Audiologica Ltd
    Feb 12, 2009
    631
    New SVS PB1000 ported suboofer available at Audiologica. SVS is now available at a new and affordable price point.
    http://www.audiologica.co.uk/svs/svs_pb1000.html
    01403 789 226
    [email protected]
    Introducing the PB-1000 – world-class SVS performance at a game-changing new price! Featuring an unbeatable combination of high-tech components, intensive engineering, and awesome deep extension and output, SVS subwoofer performance has just hit two new lows – an incredible 19 Hz and only $499!! Only from SVS – where passion and expertise combine to create extraordinary audio products.
    Awe-Inspiring Deep-Bass Extension and Output
    Only SVS has the expertise to extract this much deep-bass extension and output from a carefully sized enclosure, a high-flow 3.5" port and long-stroke 10" woofer. The result is smooth and accurate bass for music, and awesome movie performance.
    FEA-optimized motor technology for low distortion.
    Long-throw suspension for high output at deep frequencies.
    High-power voice coil for excellent thermal management.
    Lightweight 10" cone for enhanced sensitivity and transient response.
    Rubber surround for durability and long-life.
    3.5" high-flow port with inner and outer flares.
    Sledge Amplification – Intelligent and Sophisticated
    The Sledge STA-300D amplifier packs technology and sophistication simply not found anywhere else at this price point. Conservatively rated at 300 watts (720 watts peak dynamic), this amp features a highly advanced DSP processor offering unmatched control over the subwoofer at all drive levels, for the ultimate in refined behavior. The control knobs are actually digital actuators for precise and noise-free adjustment. Comprehensive and flexible connectivity options allow for easy set-up and integration into any home theater or stereo system.
    Efficient and cool-running Class D topology.
    300 watts (720 watts peak dynamic).
    Green standby mode with less than 0.5 watts consumption.
    DSP control for accurate response and refined behavior under all operating conditions.
    Stereo line-level RCA Input & 80Hz High Pass Filtered Output connections.
    Stereo speaker level 5-way binding post input connections.
    Continuously variable low pass filter frequency with disable/LFE setting.
    Continuously variable volume and phase controls.
    Attractive Styling, Manageable Dimensions, Easy Room Integration
    With an attractive premium black ash finish and black cloth grille, the PB-1000 has the styling to match its remarkable performance. With very manageable dimensions and weight, the PB-1000 is easy to integrate into any living space.
    Premium black ash finish.
    Black cloth grille.
    Dimensions: 18.4" (H) x 15" (W) x 18.4" (D).
    Weight: 46 pounds.
  2. Audiologica
    Feb 12, 2009
    631
    SVS Subwoofers
    Fresh stocks now in - selling like hot cakes!
    Audiologica, Jan 12, 2013
