New Tannoy cabs
Discussion in 'DIY Discussion' started by Jimbo, May 4, 2010.
  1. Jimbo
    Jimbo
    Nov 1, 2005
    449
    Just finished my cabinets using the 12" Monitor Golds. Took an arm and a leg to finance the wood and sundries but well worth it in the end.
    Jim.
    Jimbo, May 4, 2010
  2. Jimbo
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Good work Jim. They look great.
    It seems that Speedysteve has some competition.:)
    Dev, May 4, 2010
  3. Jimbo
    Chris Davies
    Jun 16, 2009
    218
    look lovely !!!
    Chris Davies, May 4, 2010
  4. Jimbo
    Jimbo
    Nov 1, 2005
    449
    Thanks i don't think mine would be quite as good as Speedysteve's especially in the bass as his are 15" but mine do pack a thump when there is deep bass.
    Jim.
    Jimbo, May 4, 2010
  5. Jimbo
    speedy.steve
    Dec 3, 2005
    525
    Surrey/Hants/Berkshire borders
    The finish looks 1st rate - what was the wood or veneer?
    Are they reflex / ported or some clever folded horn going on in there?
    Any pics of the build?
    speedy.steve, May 4, 2010
  6. Jimbo
    Jimbo
    Nov 1, 2005
    449
    Hi speedy.steve They are Ash veneer over Far Eastern ply.
    They are a ported design using the Onken calculator and the black slots on the lower half of the cabs are the ports. I will get some pics of the build for you. I had to look for the slimmest baffle i could find as my small room wouldn't fit in with the wide design of Tannoy's cabinets.
    I must say i am over the moon with the sound these Tannoy's produce. Had them in the loft for close on 20 years.
    Someone on a forum was praising the Monitor Golds and the high price they were fetching. I wasn't sure whether mine were the Golds, so i was well pleased when i found they were. I never had them in decent cads until now and wow do they go low. Obviously not as low as your 15 inchers but stomach thumping non the less.
    Cheers Jim.
    Jimbo, May 4, 2010
  7. Jimbo
    Jimbo
    Nov 1, 2005
    449
    There is more but i'm running out of space.
    Jimbo, May 4, 2010
  8. Jimbo
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Hi Jim,
    Instead of uploading pictures here (where we have limited space), host them on sites such as flickr or photobucket etc. and link to them as MO! explained in the following link:-
    https://www.audio-forums.com/as-rediect/showthread.php?t=14138
    Dev, May 5, 2010
  9. Jimbo
    Jimbo
    Nov 1, 2005
    449
    Yes i have tried but couldn't get the link to work. Will have another go.
    Jimbo, May 5, 2010
  10. Jimbo
    speedy.steve
    Dec 3, 2005
    525
    I use webshots as when I tried photobucket it would fail quite often - that was some time ago though.
    Nice construction too <thumbs up>
    speedy.steve, May 5, 2010
  11. Jimbo
    Jimbo
    Nov 1, 2005
    449
    Jimbo, May 5, 2010
  12. Jimbo
    Jimbo
    Nov 1, 2005
    449
    Well it works ok. Hope thats of help speedy.steve.
    As you can see with the last photo the reason for a narrow baffle. I wouldn't be able to open the door.
    Jim
    Jimbo, May 5, 2010
  13. Jimbo
    johnfromnorwich Tannerd.
    Dec 8, 2005
    276
    Always nice to see another pair of Tannoys in some well designed cabs. What internal volume are those? They look reasonably big despite the "narrow" baffle.
    johnfromnorwich, May 6, 2010
  14. Jimbo
    Jimbo
    Nov 1, 2005
    449
    They are about 127L but with internal bracing and other stuff i would say about 120L.
    Jim.
    Jimbo, May 7, 2010
  15. Jimbo
    zanash
    3,826
    Notts.
    not quite as big as I thought .......still using the same amp and cdp ?
    zanash, May 8, 2010
  16. Jimbo
    la toilette Downright stupid
    Jan 21, 2005
    1,213
    Somerset
    Very chic! Was the ash veneer expensive?
    I have the same drivers and have recently shoe-horned them into some Devon cabs while I plot my diy mkII's. Actually they sound suprisingly good in the small 45-ish litre Devon cabs!
    la toilette, May 8, 2010
  17. Jimbo
    Jimbo
    Nov 1, 2005
    449
    Yes Pete the same amp and cd. They don't look big in the photo but in the room they look larger. Your quite welcome to have a listen if your out this way.
    Jim.
    Jimbo, May 9, 2010
  18. Jimbo
    Jimbo
    Nov 1, 2005
    449
    The veneer was a 8ft x 4ft sheet which was paper backed called flexi veneer. Very easy to handle and easy to cut with scissors and no risk of tearing. The price was i think about £65 per sheet so not cheap but you do get matching veneer on the one sheet.
    Jim.
    If you need the Parameters for your drivers and the specs for my build i can email them to you if you like. Just pm me if you do.
    Jimbo, May 9, 2010
    #18
  19. Jimbo
    zanash
    3,826
    Notts.
    love too ....
    are you n the same email ?
    zanash, May 10, 2010
    #19
  20. Jimbo
    Dec 8, 2005
    276
    I'd guessed at 200+ ! Mine are just under 100L infinite baffle, which is probably the bare minimum given that my drivers are 15". I wish I had more room.
    johnfromnorwich, May 10, 2010
    #20
