New turntable arm
Discussion in 'Hi-Fi and General Audio' started by Colin2040, Oct 28, 2010.
  1. Colin2040
    Colin2040
    Feb 23, 2007
    437
    I would appreciate some advice on a new turntable arm, I am currently using an SME iii on a Luxman PD300. Shure cartridge fitted. I am considering a Jelco arm sa 250a any thoughts appreciated.Had considered a modded Rega or if I can lay my hands on a Tecno arm. Any thoughts appreciated.
  2. Colin2040
    RobHolt Moderator
    Oct 24, 2004
    9
    Hi Colin,
    Just about anything will sound better then the SMEIII.
    Great looking arm and very easy to customise for different cartridges but it sounds dynamically flat and soft compared to many other arms.
    Any Rega RB arm would sound far superior as would the Tecno.
    I've never used the Jelco but have heard something almost identical badged under other names. It too should prove better than the SME.
    RobHolt, Oct 28, 2010
  3. Colin2040
    Colin2040
    Feb 23, 2007
    437
    Thanks Rob , want to keep the cost down and I know that I can pickl up a lot of R
  4. Colin2040
    Colin2040
    Feb 23, 2007
    437
    Sorry sent that last message before I had finished. As I was going to say I know I can pick up many Rega derivatives and mod them.Thought Jelco would be a good alternative but also thought the Spall kit might be interesting. Just wondered if anyone had any other reasonably priced alternatives.
  5. Colin2040
    RobHolt Moderator
    Oct 24, 2004
    9
    SMEIIIs bring good money - ceretainly well north of £150 so that makes upgrade free or nearly free.
  6. Colin2040
    vincula
    Aug 12, 2009
    209
    Denmark
    You may want to check a Nottingham Analogue arm (Space/Mentor), a Syrinx, an Helius or a Hadcock. Incredible performers that sometimes can be found at a very low cost in the UK.
    Lovely table you've got there, btw.Absolutely worth to throw money on. Sure you'll be rewarded.
    Regards,
    Vincula
    vincula, Oct 28, 2010
  7. Colin2040
    SCIDB Moderator
    2,501
    Nice looking deck
    [​IMG]
    I would agree with trying a Rega or derivatives would be a way to go. They are plentiful and can be cheap.
    SCIDB, Oct 28, 2010
  8. Colin2040
    Colin2040
    Feb 23, 2007
    437
    I love the turntable and whats even better is that it is in pristine condition, with the SME it sounded really good I preferred it to my Notts Spacedeck and I have always preferred "normal" looking decks ie square with wood. I will remove the SME and check fitting to see what will suit the deck. Loved the Spacearm but there will not be many cheap ones about. The "bling" Spall arm appeals.
  9. Colin2040
    Colin2040
    Feb 23, 2007
    437
    Just seen the piccy it looks good with a Rega and I know where I am with a Rega cant really go wrong.The SME arm is mint as well and I have some bits and bobs and instructions etc with it.
  10. Colin2040
    Colin2040
    Feb 23, 2007
    437
    pm for SCIDB
    I have sent you pm SCIDB hopefully you can assist
    Colin2040, Dec 4, 2010
  11. Colin2040
    Colin2040
    Feb 23, 2007
    437
    Need some help here, I currently have a Luxman pd300 with an sme cut arm mount. I wantt o mount a Rega , pre 3 point fixing, so what I want to do is either get a new arm mount made, any suggestions, or has someone got the template so I can get an sme mount made at the right height with just a single hole for fixing the REGA. Any thoughts on this would help.
    Colin2040, Dec 12, 2010
  12. Colin2040
    Batty Registered Insane
    Aug 9, 2010
    30
    Adelaide SA
    Audio Origami rewired and foam filled RB250 sounds really good, but I am biased as I use one on my Rock.
    Batty, Dec 14, 2010
  13. Colin2040
    Colin2040
    Feb 23, 2007
    437
    Cant believe no one has a template that they couldnt copy for me so I can have a mount made.Found a place that makes them but they wont have any until mid January. Help still needed or do I take a brass rubbing of the sme fitting?
    Colin2040, Dec 15, 2010
