New Weiss DAC
Discussion in 'Trade Adverts and Discussion' started by Purite Audio, Nov 27, 2009.
  1. Purite Audio
    Purite Audio Purite Audio
    Nov 25, 2006
    1,250
    Weiss haveannouned a new dac, a replacement for the Minerva, fron the specs it looks interesting.
    Digital Inputs: AES/EBU or S/PDIF on 1 XLR, 1 RCA, 1 Toslink, Firewire
    - Digital Outputs: AES/EBU on 1 XLR, 1 RCA, Firewire
    - Main Analog Output: 2 stereo analog outputs, one on XLR one on RCA,
    - Headphone output on 1/4" Jack
    - Level control main output: 4 coarse settings via relays (analog domain),
    fine setting via rotary encoder (digital domain). Level control can be
    defeated for the main output.
    - Level control headphone output: 4 coarse settings via relays (analog
    domain, independent from the settings in the main output), fine setting via
    - Wordsync input on BNC
    - Wordsync output on BNC
    Frontpanel controls:
    - LCD display for display of sampling rate, input source, audio level,
    absolute phase, upsampling filter type, various menu items
    - rotary encoder with push switch
    - IR receiver
    - standby LED
    - headphone Jack socket
    Special features hidden in sub-menues:
    - transparency check (allows to check the bit transparency of a playback
    chain)
    - setting of the coarse output levels (analog domain)
    - dual / single wire selection for 176.4 / 192 kHz sampling rate
    - display brightness
    IR Remote control switches:
    - power on/off
    - volume up
    - volume down
    - input sources (4 switches for Firewire, XLR, RCA. Toslink)
    - DAC upsampling filter type
    - mute
    - absolute phase
    Sampling rates: 44.1 up to 192 khz / 24 Bits
    Mechanics: The same looks and size as the Minerva.
    The DAC202 also has a new D/A converter and new analog output stages
    compared to the Minerva. The D/A converter uses two converters per channel
    to gain in signal to noise ratio. We do not disclose any information on the
    specifics of the analog circuitry at this time.
    Keith.
  2. Purite Audio
    Nov 25, 2006
    1,250
    Price to be close to the current Minerva!
    Keith.
  3. Purite Audio
    SCIDB Moderator
    2,501
    Hi Keith,
    What is the price of this?
    Good tro meet you the other day at the bake off.
    SCIDB, Nov 28, 2009
  4. Purite Audio
    Nov 25, 2006
    1,250
    Hello Dean, very nice to meet you to, I am told it is going to be close to the old Minerva, Keith.
    Purite Audio, Nov 28, 2009
  5. Purite Audio
    SCIDB Moderator
    2,501
    Hi Keith,
    I don't know how much the old Minerva was to buy.
    SCIDB, Nov 28, 2009
  6. Purite Audio
    Nov 25, 2006
    1,250
    Dean Hi about £3k, inc vat and delivery.
    Hopefully it will be exceptionally good, hopefully even better than the DACII , very best Keith.
