novel support
Discussion in 'Hi-Fi and General Audio' started by blakeaudio, Apr 21, 2005.
  1. blakeaudio
    blakeaudio
    Apr 14, 2004
    456
    London
    just saw this on audiogon... interesting variation on the inner tube suspension....
  2. blakeaudio
    mosfet
    Jan 1, 2005
    387
    Possibly with the addition of some oil filled dampers either side it might just work! The problem with springs is that they're erm .. springy; very little internal damping and therefore prone to oscillation.
    Here's an equally outlandish idea for front-end isolation I've been musing over.
    The perfect structural isolation of a component would be to cause it to levitate in free air in an entirely de-coupled manner. Next best, in terms of structural de-coupling, is to have a low-pressure gas support (with low resonant frequency) retained by as thin a membrane as possible. Any ideas?
    Clues: made of latex, they save lives and usually pink!
    mosfet, Apr 22, 2005
  3. blakeaudio
    analoguekid Planet Rush
    Nov 14, 2003
    2,189
    Paisley Scotland, UK
    Nasty taste i'd imagine when blowing them up, yeuch, oh and how does one dampen them (and don't say with spermicide):)
    analoguekid, Apr 22, 2005
  4. blakeaudio
    mosfet
    Jan 1, 2005
    387
    Sounds daft AK, but therotically an excellent solution!
    To solve the problem of putting 'nothing' between a CD player and equipment support an inflated Johnny gets very close!
    With low inflation pressure the resonant frequency (the frequency or rate at which they wobble when under mechanical load) would also be very low, around a few Hz – giving very high damping or decoupling at higher frequencies.
    Now I wonder, what's the mark-up on a pack or re-packaged and re-branded audiophile approved isolation rubbers.. :D
  5. blakeaudio
    Nov 14, 2003
    2,189
    Good work mosy, the only thing that might better it is the opposing magnetic solution, expensive audiophile ones are out there, but i wonder if that coud be done DIY?
  6. blakeaudio
    Nov 14, 2003
    2,189
    Do you know something i might just try this, was gonna use those minimoto tubes, but i may try using rubber prophylactics instead :D could still sunstitute the inner tubes if it doesn't work.
  7. blakeaudio
    mosfet
    Jan 1, 2005
    387
    The 'Relaxa' platforms I think they're called? Also aiming for a near-perfect state of de-coupling. I did consider magnetic levitation but there are problems.
    Bring two magnets of opposing magnetic polarity together and they tend to repel each other in a lateral fashion – they push away from each other side to side rather than vertically. This would require some sort of structural retaining to solve (and defeat the purpose of a 'free-floating' platform).
    The greater problem would be the large magnetic fields – definitely not a good idea close to electronic circuits.
    Think the chemists is a better bet!
    I'm not going to ask what “rubber prophylactics†are but go forth and experiment!
  8. blakeaudio
    technobear Ursine Audiophile
    Jun 22, 2003
    2,099
    Glastonbury
    I can just see it now:
    *NEW* Russ Andrews "The Protector" Isolation Platform
    Using special low-pressure gas-filled isolating bladders made from high-grade audiophile latex (that's 'johnnies' to you and me :D ).
    Only £10,000 each so you can afford to get an extra for the weekend :lol:
    technobear, Apr 22, 2005
  9. blakeaudio
    blakeaudio
    Apr 14, 2004
    456
    London
    well you know the finanance director of ssl, the maker of "durex" told us that there condoms are strong enough to be stretched over a wheely bin, so you have to think it should be strong enought to take significant weight. the only thing is that latex degrades and might need to be stopped from druing out..... i don't even want to go there.
    blakeaudio, Apr 22, 2005
  10. blakeaudio
    rsand I can't feel my toes
    Feb 24, 2005
    903
    Liverpool
    The durex platform where audio comes first :lol:
    rsand, Apr 22, 2005
  11. blakeaudio
    blakeaudio
    Apr 14, 2004
    456
    London
    aaaaawwwwwww! that's painful. :D
  12. blakeaudio
    Joe
    Mar 15, 2005
    896
    Or try the all-new Linn Durek, as approved by the Catholic church (it keeps to the rhythm method!)
    Joe, Apr 22, 2005
  13. blakeaudio
    Nov 14, 2003
    2,189
    Or the monoblock version called Linn Dureks :D
  14. blakeaudio
    ditton happy old soul
    Sep 18, 2003
    1,261
    Edinburgh
    On recommendation, I have been using a partially inflated inner tube, child's bike size (10" diam.), and this works well. Experimenting with oak cones at the mo.
    ditton, Apr 22, 2005
  15. blakeaudio
    Feb 24, 2005
    903
    Liverpool
    The platform is particularly useful for jazz muscians who practice 'safe sax'
    rsand, Apr 22, 2005
  16. blakeaudio
    Nov 14, 2003
    2,189
    Or did you mean Jizz musicians
  17. blakeaudio
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    Oh dear, this thread is asking for trouble.
    Surely your going to have to try as many varieties as possible to see which gives the best performance. Oh its like being 21 again.
    T-bone Sanchez, Apr 22, 2005
  18. blakeaudio
    blakeaudio
    Apr 14, 2004
    456
    London
    ...and positions????
    #18
  19. blakeaudio
    lordsummit moderate mod
    3,650
    In the Northern Wastelands
    Is there going to be a high sensivity full range driver?
    lordsummit, Apr 22, 2005
    #19
  20. blakeaudio
    stumblin Kittens getting even...
    Oct 24, 2003
    350
    California!!!
    Will analogue vs. digital be replaced with latex vs. polyeurathane? How about those jobbies made out of sheep bits?
    stumblin, Apr 22, 2005
    #20
