OB1 vs. SCM35
Discussion in 'Hi-Fi and General Audio' started by andyoz, May 2, 2006.
  1. andyoz
    andyoz
    Sep 18, 2004
    1,117
    A question for the more seasoned listeners out there....
    If I were to change from SCM35's to OB1's, what differences would I hear? They both come from companies that appear to have some similarities but I think their products probably sound COMPLETELY different.
    Amp is ATC SPA2-150 and room is approx 14ft x 20ft.
    And before you ask, due to location there is no way I can ever demo them side by side (that would involve a plane trip!).
    Any comments appreciated.
    p.s. please don't let this spiral into another ATC/PMC bashing session (it's been done already) - I am not trying to bait anyone at all, just looking for good, honest opinions.
    andyoz, May 2, 2006
  2. andyoz
    rodrat
    Dec 1, 2003
    295
    St Albans
    I suppose it would depend on what you feel the scm35's are missing for you to want to consider the change. I have OB1's but have never heard the scm35's.
    Rod
    rodrat, May 3, 2006
  3. andyoz
    andyoz
    Sep 18, 2004
    1,117
    It's mainly the bottom end and rather "dark" nature to their sound.
    The bottom end of the SCM35 at first appears to be weighty and extended but there really isn't much substance to it at all, particularly with rock/pop material.
    I have heard them go very low on some material but then on other material there's virtually nothing. It's a case of feast or famine regarding the bass. I guess they are just accurately presenting the source and if so then I need a speaker that doesn't exhibit that trait.
    andyoz, May 3, 2006
  4. andyoz
    anubisgrau
    Mar 24, 2006
    663
    well what virtue would be than an alternative?
    anubisgrau, May 3, 2006
  5. andyoz
    andyoz
    Sep 18, 2004
    1,117
    I guess I need something that has what might be called bass "bloom". Not necessarily accurate but still enjoyable.
    It's funny but I have an old 12" 2-way Fender keyboard amp that I sometimes play music on. I actually enjoy the bass from that more than the ATC's at times - it is defiinately not accurate, but still no less enjoyable.
    Guess I'm not an Audiophile really, just a head banger.
    andyoz, May 3, 2006
  6. andyoz
    Nomoretweaks Tourist on tilt
    Dec 9, 2004
    265
    Richmond
    Expect more accentuated freq. extremes and recessed and comparatively less natural mids.
    "Feast or famine" is a very good description - I had the same experience, measurements in my room showed sharp raise in about 20-100 Hz with a dip in 30-40Hz. No wonder I could not hear some bass notes. I use TacT DRC now, ATC are robust enough to handle dips correction.
    Nomoretweaks, May 3, 2006
  7. andyoz
    Dec 9, 2004
    265
    Richmond
    You are not the only one - against all odds and common wisdom I preferred the bass from some underpowered amps with 35s - including an old 50-watts Quad 306 - more relaxed and enjoyable. With TacT I need a really powerful one, so I use Bryston.
  8. andyoz
    andyoz
    Sep 18, 2004
    1,117
    It's a funny game.
    I just got a pair of these for £140 off eBay to use with a Squeezebox in the bedroom system.
    http://www.jblpro.com/pages/recording/lsr25p.htm
    They have a really dynamic, brash and up front sound and I am loving it! No hint of the SCM35 "dark" presentation here.
    andyoz, May 3, 2006
  9. andyoz
    andyoz
    Sep 18, 2004
    1,117
    Do you mean expect that with the ATC's. I have tried other speakers (i.e. large standmounts that are too ugly for the missus) in that room and the botom end just seems more evenhanded and weighty.
    Why is ATC bass so weird sometimes?
    andyoz, May 3, 2006
  10. andyoz
    anubisgrau
    Mar 24, 2006
    663
    because it is correct.
  11. andyoz
    andyoz
    Sep 18, 2004
    1,117
    OK, point taken.
    andyoz, May 3, 2006
  12. andyoz
    Dec 9, 2004
    265
    Richmond
    No I mean expect it with OB1.
    Because it is very tight - lots of slam and enegry but shortened bass note sustain and deay. Why does it happen I do not know, I think it has something to do with the closed cabinet design and a huge bass driver magnet. When I bought them I kept guessing - was it bass heavy or bass light? There is a hammer-like slam and then.. nothing. The driver stops very quickly. So when you have an amp that is unable to control it - the bass lackes the slam and becomes a bit loose and often it is more enjoyable. Very tricky speakers indeed.
  13. andyoz
    andyoz
    Sep 18, 2004
    1,117
    Ahhh, very interesting post.
    I actually see exactly where you are coming from. The ATC amp I am using is a current monster that has a vice like grip on the bass driver.
    I just don't get the impression of speed and slam from the ATC's that I would like. I just get either nothing, or something that's a bit low and loose. Repositioning them doesn't seem to change this trait.
    Jazz and classical is a different matter - they just sing. Shame I never listen to it!
    andyoz, May 3, 2006
  14. andyoz
    Feb 23, 2005
    935
    I think it was the OB1's that I listened to at the heathrow show. They were amazing (despite being powered by awful an Arcam pre/power). Nice dimensions too. Similar bass output to the Coincident speakers but a lot cheaper IIRC. Very nice.
    Dynamic Turtle, May 3, 2006
  15. andyoz
    anubisgrau
    Mar 24, 2006
    663
    how can a speaker be correct with one type of music and not correct with another.
    i think these complaints should go to the lousy production first of all. it is true that with ATCs you hear so many (too many?) bad things done in studios. i was shocked first time i heard bjork's medula. spit all over studio!
  16. andyoz
    andyoz
    Sep 18, 2004
    1,117
    I completely agree. You should have heard what came out of the ATC's when my wife played a Spice Girls album (it's her CD - honest)...it was just plain weird. But then that stuff sounds great on cheap gear.
    And the studio production techniques are getting more invasive. The ATC's show up compression techniques particularly well. In contrast, Michael Jacksons "Off The Wall" album sounds majestic but I know that has been done by a producer/artist who (used to) know his stuff.
    I guess the real question is - is it really spending loads of money on gear for rock/pop replay - I am quickly coming to the conclusion that the answer is NO.
    andyoz, May 3, 2006
  17. andyoz
    anubisgrau
    Mar 24, 2006
    663
    it is a known trick of trade that populist music is produced and mastered to work on cheap devices. you should hear spice girls on a ghetto blaster.
  18. andyoz
    andyoz
    Sep 18, 2004
    1,117
    Best one was Pete Waterman.
    Did you ever wonder why his 80's stuff has crazy hi-hat/cymbal patterns. The clever bugger figured out that it sent the disco light shows crazy as they were triggered by high frequency energy. Got the punters up and dancing and shifted more units.
    He also purposefully mixed his tracks with minimal low-frequency energy as it tricked the radio station compressors and his tracks came out playing louder over the airwaves.
    Basically, Audiophile tendancies and pop/rock do not mix really.
    andyoz, May 3, 2006
    #18
  19. andyoz
    Dec 9, 2004
    265
    Richmond
    Do not want to dissapoint you, but I asked Larry Cox (he is a US reviewer and used to have ATC 35 as his reference speakers) and he advised me against using this amp, he thinks the older, black one (don't remember the model) is much better with ATC. He said he had one of the best results with a Chord power amp. He himself used 35s with EAR 509 monoblocks.
    #19
  20. andyoz
    technobear Ursine Audiophile
    Jun 22, 2003
    2,099
    Glastonbury
    I had a similar problem with SCM12's. I guess it's a house sound.
    I hate to spoil your ATC/PMC love-in but I suspect you need Dynaudio.
    technobear, May 3, 2006
    #20
