One for the 'believers'
Discussion in 'Hi-Fi and General Audio' started by Tenson, Jul 8, 2007.
How much does a really good cable cost?
  1. £1-£49
    40.0%
  2. £50-£99
    20.0%
  3. £100-£199
    22.0%
  4. £200-£499
    8.0%
  5. Over £500
    10.0%
  1. Tenson
    Joe
    Mar 15, 2005
    896
    £50 is the price of a decent bottle of claret. Serious money in my book.
    Joe, Jul 9, 2007
    #21
  2. Tenson
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    deoxywatsit: absolutesybollox.
    polish your pins, don't waste money on an a deoxidising agent that doesn't even has a chemically active ingredient warning.
    its good for pots, and nowt else.
    sq225917, Jul 10, 2007
    #22
  3. Tenson
    Tenson Moderator
    Nov 12, 2003
    5,947
    I suppose given the comments I should have asked where you cable 'believers' feel diminishing returns sets in with regards to price?
    Thanks for your votes so far, it is interesting at least that the £100-200 bracket is starting to pull ahead a bit.
    Tenson, Jul 10, 2007
    #23
  4. Tenson
    dcathro
    Sep 9, 2005
    105
    "cable 'believers'" - There's something a bit condescending about this term, like they're whackier than scienologists or people who believe in UFO's.
    I am not a believer, although I have some that I like, and lot's that I don't.
    dcathro, Jul 10, 2007
    #24
  5. Tenson
    AlexTaylor
    Nov 13, 2005
    163
    I think the poll question is a bit duff. There are cables I consider really good at all the above price points, and ones in particular that get better the more money you spend. Similarly I have heard some cacky ones for a grand.
    AlexTaylor, Jul 10, 2007
    #25
  6. Tenson
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Thats very restrained, Ian.
    DavidF, Jul 10, 2007
    #26
  7. Tenson
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    I think non beleivers are those that beleive a piece of bell wire is as good as anything else and anything else is a waste of time?? (Ian/Simon/Tones?)
    Therefore you woould be considered to be a beleiver?
    #27
  8. Tenson
    johnfromnorwich Tannerd.
    Dec 8, 2005
    276
    I think that's a bit disingenuous :) The sceptical view is that provided two cables measure as electrically equivalent and are adequetely shielded they will sound the same. Since fifty quid will easily get you a well shielded, well constructed conductor, this does seem like a reasonable bottom rung fo the poll. In fact even Zanash's Type 1 silver are only this kind of money, I seem to remember. I'm pretty sure I've never spent more than this
    johnfromnorwich, Jul 10, 2007
    #28
  9. Tenson
    sideshowbob Trisha
    3,092
    London
    Correct. It's also very important to remember that it's almost certain that the wire in your £500 interconnect is pretty much the same as that in a £10 version from the high street, as almost no boutique cable company actually makes wire, they buy off the shelf stuff from RS Components and the like and put it in a nice sheath, maybe do some plaiting on it. They are not "cable manufacturers" in any real sense.
    -- Ian
    sideshowbob, Jul 10, 2007
    #29
  10. Tenson
    ADPully
    May 20, 2007
    265
    Oxford
    This data is useful to know - My conclusion 50% of us who think cables make a difference think there is some value in spending more than £50 on an IC. I would still be interested in know the relative proportion of people on this forum who think there is no value in spending more than £10 - my guess its around 10% ?
    FYI most expensive IC cable purchase for me was £124 - many years ago for some new Audio synthesis silver blue. I find it detailed and explicit but ultimately a little tiring to listen to over a whole evening when compared with some mid price audionote stuff I have loaned from a mate. I am now most likely to buy my next cables second hand probably silver. If I found stuff similar in sound to the AN stuff but cheaper I would buy it
    ADPully, Jul 10, 2007
    #30
  11. Tenson
    Effem Cable manufacturer
    Jan 27, 2005
    269
    Sunny Cornwall
    So too would a lot of others :D I had until recently a set of the Audion Note Japan QSSC interconnects in my system so I know exactly what you mean.
    Effem, Jul 10, 2007
    #31
  12. Tenson
    murray johnson
    Mar 23, 2006
    418
    I can think of two that do & both make extremely good, if expensive, cables. However I'd agree that most are made using off the shelf wire and are much of a muchness performance wise.
    murray johnson, Jul 10, 2007
    #32
  13. Tenson
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Apologies..:rolleyes:
    I'm sure you're right Ian.
    I'm currently (no pun intended) using silver /gold cables (a la Pete)....the next ones I like are Petes platanum alloys (have I got it right this time, pete?).
    I have to say I wouldn't buy off the high street as they seem over priced.
    #33
  14. Tenson
    Jan 11, 2007
    1,514
    surely the whole point of buying home made is that you make them yourself.
    #34
  15. Tenson
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    You can't do everything.
    I wish you (I) could
    #35
  16. Tenson
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    I agree, thats an interesting one.
    (I don't dare lsten to anything TOO good though; you know you going to have to give it back....:())
    #36
  17. Tenson
    hifi addict
    Sep 26, 2006
    505
    Hastings
    It depends on your system. My cable set comes to £6K. But thats my personal choice. Saying that I heard some cables costing £15K which I thought sounded shut in and compressed. Then I heard some cheap bell wire sound fantastict!.
    I'm confused now.
    Try before you buy.
    hifi addict, Jul 12, 2007
    #37
  18. Tenson
    sastusbulbas
    May 21, 2006
    275
    Edinburgh
    I find a balanced system to be quite revealing of cable choices, no different to a single ended system ?
    I would also suggest that choosing cables and expecting differences would depend on ancillary choice also, A $200 amp and $200 CD player with $200 speakers may not show much difference between a $5o and $500 cable, take it up to $2k per box and things should change, at $10k per box yet another window may be opened to what capabilities a certain cable may possess.
    sastusbulbas, Jul 13, 2007
    #38
