Optical cables
Discussion in 'Hi-Fi and General Audio' started by rsand, Dec 15, 2010.
  1. rsand
    rsand I can't feel my toes
    Feb 24, 2005
    903
    Liverpool
    Is there really any difference between them? I notice PMMA (polymrthylmethacrylate) ones are touted as best but surely there can be no difference with optical?
    I'm comparing CAMBRIDGE AUDIO DIG300 which is PMMA and the IXOS XHD308 made from medical grade fibre optic cable, both are £20 at Richer.
    Thanks :confused:
    rsand, Dec 15, 2010
  2. rsand
    RobHolt Moderator
    Oct 24, 2004
    9
    My experience is that different types will give the same performance if kept short - so up to 2 meters or so and any type should be fine.
    When using long cable over 3 meters I've evidenced some variability and certainly with 5m+ you'll get some that are a lot better than others.
    RobHolt, Dec 15, 2010
