Optrix equivalent 'home brew' and mains cable resources
Discussion in 'DIY Discussion' started by zega5508, Jan 13, 2008.
  1. zega5508
    zega5508
    Dec 20, 2007
    11
    Hi everybody
    Optrix (see audiocandy) is an excellent cleaner of cd's. The principle is that it removes manufacturing residues which are not removed after the disc is pressed.
    Bottle says isopropyl alcohol and optically active nonionic surfacants. Has anyone created an equivalent and what are your ingredients? Costs? Sources?
    Part 2
    Double shielded mains cable. Has anyone found a UK based source that will sell off the reel ie less than 10 metres? Any european sources that won't have import duty. I've found all the Belden USA based stuff but understand import duty is huge.
    Belden equivalents anyone - Know Lapp?
    Cheers zega5508
  2. zega5508
    zanash
    3,826
    Notts.
    At the risk of going against the current rational on this forum....
    yep those mains cables will be audibly better than the standard kettle lead.
    pm me if your interested in lapp
    zanash, Jan 15, 2008
  3. zega5508
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    :duck:
    DavidF, Jan 15, 2008
  4. zega5508
    6,766
    bucks
    theres all sorts to clean cds with.
    have used anti static photocopier cleaning fluid (seems to do a great job), and failing that even window cleaner.
    Doesn't seem to require special items to me.
    On mains cables, if you're buying a couple of metres from someone with a reel that's a nice cheap way to try something. Why not give it a go if you feel like it.
    You might find a few sparkies here or on sites dedicated to recording music who can give you a few metres of something for a pittance.
    bottleneck, Jan 15, 2008
  5. zega5508
    rockingdoc
    Jan 17, 2008
    Kent
    Haven't found anything to better washing up liquid under a running tap to clean CDs. Works for me.
    I made up a load of screened mains leads but stopped using them because they were too bulky and heavy. Didn't notice any significant change in sound.
    rockingdoc, Jan 17, 2008
  6. zega5508
    rollo
    Nov 30, 2006
    339
    N.Y. U.S.A.
    Priceless Dave.
    rollo
    rollo, Jan 17, 2008
  7. zega5508
    zega5508
    Dec 20, 2007
    11
    Thanks all
    Will try and find some photocopier cleaning fluid. I think it was Rob Schofield had created his own caig like rca cleaner? This was a blend of all sorts of things.
    Mould release agent was the key with the optrix - it takes off what is left on the disc during manufacture. So I'm not talking about finger prints here.
    Double shielding works on mains cables + earthing the shield - likewise on interconnects.
    zega5508
    zega5508, Jan 19, 2008
  8. zega5508
    zanash
    3,826
    Notts.
    As an experiment ...build two identical ic 's shield one and ground at the source end ..leave the other un shielded ....
    listen and report back which sounds best !
    A number of people have been rather surprised by the outcome.
    Cd cleaners ...try a drop of surfactant or a wetting agent[used in film processing] in distilled water ..this is gentler than detergent.
    zanash, Jan 19, 2008
  9. zega5508
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Thankyou.
    :D
    DavidF, Jan 19, 2008
  10. zega5508
    demandcurve
    Jan 6, 2004
    34
    Guildford, Surrey
    IPA is a general purpose chemical solvent. Manufacturers sell it by the 20 tonne truck load but you can buy 5 litres for a tenner on eBay. You can also use for many purposes such as de-icing your locks and windscreens, and its probably in your windscreen wash already - should you wish to use that for washing CDs. Nonionic surfactant is like detergent, it mixes with water and oil: it's job here is probably to allow the solvent to spread evenly over the surface and prevent the solvent beading up.
    I never tried cleaning a CD, can you hear a difference afterwards?
    Tony
    demandcurve, Jan 25, 2008
  11. zega5508
    Jimbo
    Nov 1, 2005
    449
    Certainly can if its especially grubby with fingerprints and such. Clean one and see if you can and let us know.
    Jimbo, Jan 25, 2008
  12. zega5508
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    I breath on mine and then wipe them across my pants.
    then that's it,
    sq225917, Jan 25, 2008
  13. zega5508
    Tenson Moderator
    Nov 12, 2003
    5,947
    Same here :D I have nonionic pants for this purpose!
    Sometimes I wipe it on my cat, but this is not as good sonicly.
    Tenson, Jan 25, 2008
  14. zega5508
    speedy.steve
    Dec 3, 2005
    525
    Surrey/Hants/Berkshire borders
    The breathing technique is good :)
    I make my own main cables out of HT100. Nice OFC copper etc etc.
    speedy.steve, Jan 30, 2008
  15. zega5508
    zega5508
    Dec 20, 2007
    11
    For the shining wits above - you are missing out! I guarantee you will here the difference if you strip off the remaining manufacturing residue.
    Fairly simple test really - play it dirty-clean it and listen.
    I've created a blend from some leftover contact lens hydrogen peroxide solution, some normal Renu lens solution, some good old Bells Scotch Whisky (40% alcohol) and domestos spray bleach.
    You will read that some sacd manufacturers do not recommend surface cleaning with chemicals - so don't.
    You can breath on them all you want but it won't take off the manufacturing gunk.
    Try a dab of neat spirits - you will be surprised. You can always breath on it and shine it on your cat afterwards - or was that your nonionic trousers.
    Zega 5508
    zega5508, Feb 4, 2008
  16. zega5508
    speedy.steve
    Dec 3, 2005
    525
    I got hold of some Lapp Öflex classic 110 CY 3G 2,5. Not too bulky and quite flexible unlike my HT100 homebrew.
    I must say I rather like it.
    speedy.steve, Feb 15, 2008
  17. zega5508
    zanash
    3,826
    Notts.
    its ok .....much better than the standard kettle lead....imo
    zanash, Feb 18, 2008
  18. zega5508
    O'Shag
    Feb 26, 2008
    41
    :D Excellent!!
    O'Shag, Feb 26, 2008
    #18
