Paradigm Monitor Series at Audiologica
Discussion in 'Trade Adverts and Discussion' started by Audiologica, Feb 22, 2013.
  1. Audiologica
    Audiologica Audiologica Ltd
    Feb 12, 2009
    631
    Paradigm Monitor series offer amazing quality at very realistic prices - you get far more for your money than with the the "usual suspects"
    www.audiologica.co.uk/paradigm
    01403 789226
    [email protected]
    Now in its seventh iteration, each new generation is an opportunity for refinement: design innovations from our higher-priced reference lineups, reference-quality component parts, cabinets and even finishes! When it comes to getting value for your money, it doesn’t get better than Monitor Series 7. Since its inception, the Monitor Series has been a favorite of audiophiles on a budget — with Series 7, that hasn’t changed.
    The Building Blocks: Monitor Drivers
    Advanced S-Pal™ Satin-Anodised Pure-Aluminium Bass/Midrange Cones. First seen in our Paradigm Reference lineup, very high stiffness-to-mass ratio and outstanding internal damping. The result? Remarkable midrange clarity, superb extended bass response and freedom from unwanted resonances and distortions. In an affordable audio category – unbelievable quality!
    Advanced S-Pal™ Satin-Anodised Pure-Aluminium Domes with powerful neodymium magnets and ferro-fluid cooling for increased power handling! Highs are more soaring and spacious, crystal clear and undiluted even at the higher bandwidths.
    Wire Mesh Tweeter Guard and WaveGuide™. More Reference technology, ensuring a smooth, wide panorama of audiophile-quality sound. Wire mesh protection for the pure-aluminum tweeter.
    Sophisticated crossovers in an affordable audiophile product! Again, it’s almost unheard of: polypropylene film or bipolar electrolytic capacitors, air core and laminated core inductors, high-power resistors. Crossover topologies are first and second-order with corresponding acoustic slopes of second and third-order providing optimal bandwidth and seamless integration as drivers cross over.
    Long-Travel Motor/Magnet Structures. Despite fewer drivers than in previous series’, floorstanding and center channel speakers actually plumb deeper. This is, in part, attributable to the advanced motor/magnet structures: high-temperature copper or aluminum wire voice coils (varies by model) wound on Kapton formers, oversized magnets with all components FEA-optimised.
    Foam-Rubber Elastomer Surrounds. Reference Studio Series geometry! Help achieve that play loud AND play deep effect by allowing longer, expertly controlled cone travel.
