PC vs Laptop
Discussion in 'General Chat' started by Heavymental, Jan 12, 2007.
  1. Heavymental
    Heavymental
    Dec 10, 2003
    877
    I've been thinking of getting a laptop for a little while. Not because I need the portability but more for the generally smaller size. However, after speaking to a few people, having a look in the shops and reading some threads here I'm now thinking maybe I should just get a small PC. If I get a mini box with a flat screen It could be a fairly unobtrusive setup. I'm also thinking that it may last longer than a laptop which alot of people seem to suggest is likely to die within a couple of years. Are PC's generally more robust?
  2. Heavymental
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    I've recently acquired my first laptop. I have barely touched my desktop since.
    It's a matter of how it fits into your life, but for me a laptop is proving extremely useful.
    By their nature desktop PCs will be more robust because they're not being carted about the place. If you moved one around as you would a laptop, it wouldn't last 10 minutes.
    I-S, Jan 12, 2007
  3. Heavymental
    andyoz
    Sep 18, 2004
    1,117
    I read somewhere that laptops are now outselling desktops for the first time.
    I think the current laptop speeds are so good that the extra performance of a desktop is less of an attraction (except for gamers, etc.).
    The latest range of processors also appear to run cooler so less noise from fans and hopefully less thermal stress in general?
    In general, I still think a desktop will be less "strained" due to heat load, etc. so they probably will last longer. Nothings certain with computers though and I don't see why a well treated laptop from the likes of HP, etc. shouldn't last 5 years. Mine always have. :D
    andyoz, Jan 12, 2007
  4. Heavymental
    rodrat
    Dec 1, 2003
    295
    St Albans
    Personally I hate using laptop keyboards but especially the pointing device. At work I plug in an external keyboard and moiuse which simewhat defeats the object. Yes they are small but the battery charge doesn't last long and if you plug it into the mains you might as well have a pc. Why not go for a mac mini running windoze.
    Rod
    rodrat, Jan 12, 2007
  5. Heavymental
    mr cat Member of the month
    Jul 31, 2003
    3,375
    5
    I've got both - I haven't touched my PC since I bought it - it's just so convient - I'm able to place it on my coffee table and surf whilst watching tv etc...!
    I've also had it 18 months (second hand) without any problems...
    mr cat, Jan 12, 2007
  6. Heavymental
    Jun 25, 2003
    4,842
    In a world of pain
    Actually, the Core 2 Duo powered laptops do last very well on battery power. My T7200 powered laptop easily gets a real-world 6 hour runtime (using wifi, browsing web, running office apps, etc). Most will do 4 hours or so (Mine is one of the best rated for battery life and I have the extended battery pack... with low screen brightness, no wifi, etc it is possible to squeeze out 8 hours of runtime).
    Certainly they're a very different affair to the likes of the desktop P4 powered laptops where an hour was wishful thinking.
    I-S, Jan 12, 2007
  7. Heavymental
    andyoz
    Sep 18, 2004
    1,117
    Yes, my old Pentium Mobile powered laptop used to drive me nuts, bloody fan noise especially.
    My new Core-2-Duo powered laptop is a dream. Laptops have really come into their own now in many ways.
  8. Heavymental
    Jul 31, 2003
    3,375
    5
    yeah, mine's an old 2.8ghz - battery life and fan noise far from ideal - but I normally just have the power lead in - but still stops me from using my desktop...!
  9. Heavymental
    PBirkett VTEC Addict
    2,456
    The Toon
    I've just traded my desktop for a laptop. In short, I wouldnt go back. You get used to the keyboard and touchpad anyway.
    PBirkett, Jan 12, 2007
  10. Heavymental
    Heavymental
    Dec 10, 2003
    877
    Hmm ok. What about price. Would a PC be significantly cheaper than the equivalent laptop setup?
    In my first post when I said 'robust' I meant in a lifetime sense. I'd been led to believe that laptops have more problems (not necessarily attributable to a physical cause). I.e software failures and operating problems. Not a computer buff myself so I'm afraid I can't go into much depth! But thats why I had considered a PC instead.
  11. Heavymental
    Jul 31, 2003
    3,375
    5
    what kind of budget and performance you after..?
    from what I've seen there is some loss of performance (per pound) compared to a desktop but overall I think you'd be happier with a laptop...
  12. Heavymental
    1,964
    What about an iMac, its the smallest form factor desktop solution out there.
    garyi, Jan 12, 2007
  13. Heavymental
    2,456
    The Toon
    Laptops, pound for pound, are definitely quite a bit slower than desktops. However, for me, the convenience factor outweighs this. And if you dont play games, its not that much of an issue to me.
  14. Heavymental
    Heavymental
    Dec 10, 2003
    877
    My budget is about £600 but from reading past threads here I realise I need to factor in a 3 year warranty into that. I'll mostly be using it for storing photos and uploading them onto photobox. I use the net at work so won't be online too much really. I don't tend to fiddle with my pics too much so I'm not after outstanding performance but would require it to be fast enough to deal with big files and have a decent size hard drive.
    Heavymental, Jan 15, 2007
  15. Heavymental
    Jul 31, 2003
    3,375
    5
    ok - then a laptop would be fine...however, mine has an avereage screen - you may need to check them out with good resolutions..??
    I'm not an expert on this - but a bog standard crt seems to be better than a lcd...
    but go and have a demo!
    mr cat, Jan 15, 2007
  16. Heavymental
    Heavymental
    Dec 10, 2003
    877
    Well, sounds like I should go down the laptop route. I guess having the portability option is a plus even if it'll only be travelling between rooms. Next stage is to keep an eye out for a decent deal. There seem to be plenty of good options through ebay shops once you specify your needs.
  17. Heavymental
    Jul 31, 2003
    3,375
    5
  18. Heavymental
    Heavymental
    Dec 10, 2003
    877
    Thanks Mr Cat. Ebuyer looks a good place to buy laptops. Was going to look at Dell but I've heard they are pretty poor for customer services.
    #18
  19. Heavymental
    1,964
    If you are even mildly interested in photographs I would think again on a laptop, unless very highly specced one you will be getting a chap and nasty screen.
    garyi, Jan 15, 2007
    #19
  20. Heavymental
    greg Its a G thing
    Dec 30, 2003
    1,687
    Wiltshire UK
    I'd second Gary's comment. the screen is the one thing you can never change. What seems like a great deal on spec, or very cheap, can over time feel like money wasted if the screen isn't right for your needs.
    Naturally you can plug into an external screen, but I mean if the laptop won't be used with a separate screen.
    greg, Jan 15, 2007
    #20
