please help
Discussion in 'DIY Discussion' started by marialaina191ax, Apr 24, 2006.
  1. marialaina191ax
    marialaina191ax
    Apr 24, 2006
    :confused: i have got a hotpoint v t d oo aquarius tumble dryer my friend took the front off it to fix the timer now he doesnt know where the wires go i need a diagram so he knows were they go x
  2. marialaina191ax
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    This is a hifi forum... you might get better help on a domestic appliances forum.
    Around here, you're most likely to get suggestions like changing the wires for ones that cost three times as much, or not to bother with that because DIY ones work as well, to those who suggest that the wiring makes no difference at all. Otherwise, put it on mana.
    I-S, Apr 24, 2006
  3. marialaina191ax
    t1nt1n hifi collector
    Mar 5, 2006
    35
    t1nt1n, Apr 24, 2006
  4. marialaina191ax
    zanash
    3,826
    Notts.
    pm me I've done somthing similar in the past.
    zanash, Apr 25, 2006
  5. marialaina191ax
    Tenson Moderator
    Nov 12, 2003
    5,947
    :D I can see it now!
    Tenson, Apr 25, 2006
