Top of the Plinius range, this is the brand where you do not pay for the name - just for the superb build quality and sound of some of the finest audio products on the market. Can run in Class A or A/B at just the press of a button - depending upon your preference! Read any one of the glowing reviews to see why this amp is amongst the best of the best and won numerous awards. Absolutely as new condition with wooden crate. Power: 300 watts RMS per channel into 8 Ohms, 450 watts RMS per channel into 4 Ohms. 1000 Watts per channel into 8 Ohms in bridged and true balanced mono modes. Both channels driven from 20Hz to 20kHz. Frequency Response: 20Hz to 20kHz ± 0.2dB. 0dB at 0Hz and -3dB at 70kHz Distortion: Typically < 0.05% THD at rated power. 0.1% THD and IM worst case prior to clipping Current Output: 100A short duration peak per channel Fuse protected Rise Time: Typically < 4µS Hum & Noise: 100dB below rated output 20Hz to 20kHz A-weighted Input Impedance: 47k Ohms Gain on RCA Inputs: 32dB Gain on Balanced Inputs: 38dB Dimensions: Height 275mm (10.75"), Width 510mm (20"), Depth 535mm (21") Weight 57kg
