Plugs for ports
Discussion in 'DIY Discussion' started by SteveC, Oct 28, 2003.
  1. SteveC
    Aug 31, 2003
    854
    SE Norway
    Hi -
    Anyone know where I can get a pair of foam plugs for ports, 2 1/2" diameter? I don't want a huge amount of attenuation, maybe 3 dB.
    I know the solutions like drinking straws, socks, etc. but I'd like to get the proper thing to try. TIA.
  2. SteveC
    technobear Ursine Audiophile
    Jun 22, 2003
    2,099
    Glastonbury
    Send an email to the manufacturer of your speakers?
    Or if the speakers are DIY, just try various manufacturers (e.g. B&W, KEF, Tannoy, Wharfedale, Monitor Audio - all of these ship speakers with bungs so may be willing to help you).
    technobear, Oct 28, 2003
  3. SteveC
    Aug 31, 2003
    854
    SE Norway
    Yes, I thought of those things, but it would be easier if I could simply order from a speaker builder. Trouble is, neither Falcon nor Wilmslow have them on their on-line stock-lists.
  4. SteveC
    avanzato
    Sep 20, 2003
    260
    Would a foam water filter for a pond pump do the job. There's a shop down the road that has round ones in the window. Might be too open cell for your purposes but I'm sure you could get a large one and sqeeze it into the port.
    avanzato, Nov 10, 2003
  5. SteveC
    Aug 31, 2003
    854
    SE Norway
    Hmmm that's an interesting suggestion -- I'll have a look in the local pet shop!
    SteveC, Nov 10, 2003
  6. SteveC
    michaelab desafinado
    6,403
    Lisbon, Portugal
    michaelab, Nov 10, 2003
