Pots
Discussion in 'DIY Discussion' started by T-bone Sanchez, Jul 1, 2005.
  1. T-bone Sanchez
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    Any way of increasing the resistence of a volumn pot? Ive a 10K but could do with 20K for a project. CPC dont have a 20K and I dont want to buy a alps etc. Any ideas?
  2. T-bone Sanchez
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    How is it implemented? Can you change the value of the shunt (if there is one)?
    I-S, Jul 1, 2005
  3. T-bone Sanchez
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    There isnt a shunt but I think I might be able to do it. Its simply the two lines in/out plus a ground (I just solder across the two pins to ground). What are you thinking, a resistor to ground?
  4. T-bone Sanchez
    zanash
    3,826
    Notts.
    It depends if you want to attenuate the incoming signal ....the 10k pot will make things louder than the 20k pot.. or you could attenuate the out going signal...use the old L pad method resistor in line and one to ground for each signal. I don't have to hand the attenuation rates...but they should be on the web somewhere.
    Alternatively get a bourns conductive plastic pot there cheap enough ...mind the alps from RS are only about £15 [if I've got the right ones]
    zanash, Jul 2, 2005
