sorry, this is a rather basic question, but perhaps someone can help enlighten me...? I've got a Musical Fidelity x-as100 power amp, which has a mono/stereo switch to allow bi-amping. The manual shows an arrangement (with mono switch in) where a an As100 is used to power each speaker, with one set of outputs going to the HF connections, the other to the LF connections (obviously, used with a biwirable speaker). Can I do this with a non-biwirable speaker (ie + on speaker connected to both + outputs on amp, - on speaker connected to both - amp outputs)? The description on the MF website seems to suggest this is fine: "By 'mono-ing' the X-AS100 and joining the speaker connections, the X-AS100 can be turned into a 100 watt, 60 amp monobloc. This allows a second unit to be added, for a stereo pair. This simple upgrade path gives even greater dynamic control. Alternatively, two X-AS100s can be 'mono-ed' easily for passive bi-amping." It's just there's no reference to this in the manual so I want to be sure I'm not going to blow anything up.... The 2nd part of my question is... Used as a stereo amp, it's rated I think as 100W, 35 amps per channel. As a monoblock, it's 100W, 60 amps. What does this actually mean? Surely the same amount of power (100w) is going to the speaker, with higher current but (presumably) lower voltage? Is this going to provide any benefit? I would have thought the idea would be to provide a higher wattage?
