would it be a good idea to upgrade the power cables on my amp and cd player? both of which are hard wired. i dont think it will be that hard to make some up myself, what cable would you recommend, without spending a massive amount of mney, and also will std homebase 3pin plugs do the job or would u recommend something better? thx matthew
