pre amp <£100
Wanted: Discussion in 'Classified Adverts' started by Coda II, Mar 29, 2007.
  1. Coda II
    Coda II getting there slowly
    Nov 17, 2004
    603
    Devon
    don't need remote control, phono stage or multiple inputs
    do need it to be less than £100... in fact half that would be good!
    thanks for looking
  2. Coda II
    dreftar
    Jan 3, 2006
    490
    Shetland Islands
    Why not try a DIY or mod. At my local electrical store there is a device for switching between phono inputs and an output at £12.99 add an Alps Pot around £15 a bit of silver wire some soldering and whoody doo you have a passive pre amp and some change for at least one 180g vinyl spinner
    dreftar, Mar 29, 2007
  3. Coda II
    Tenson Moderator
    Nov 12, 2003
    5,947
    I'm putting in an order with RS now, £30 and I'll build you a alps pot in a box to go with the amp. Its about as good as you will get for under £50 I expect.
    Tenson, Mar 29, 2007
