Primare DVDi10 ex-demo plus 10% of Eclipse TD speakers
Discussion in 'Trade Adverts and Discussion' started by Audiologica, Feb 20, 2010.
  1. Audiologica
    Audiologica Audiologica Ltd
    Feb 12, 2009
    631
    Ex-demo models available in either black or titanium finish - brilliant award-winning system, classy looks and fantastic performance at a bargain price of just £1295
    The DVDi10 also works perfectly with the Eclipse TD range of speakers - we are offering 10% off RRP of any pair of Eclipse speakers when purchased with the DVDi10
    http://www.audiologica.co.uk/primaredvdi10.html
    01403 789 226
    [email protected]
    The new DVDI10 features a high performance proprietary Class D amplifier system to be compared to some of the best of class-AB amplifiers. It draws from music and film sound a sense of authority that belies the system's 75 watt (into 8 ohm) per channel specification. World class performance in the entire audio band has been achieved by carefully choosing components and refining Class D technology to a layout that is as simple as it is efficient.
    Generating very little heat while being extremely efficient, this technology is perfectly suited to the ultra-compact DVDI10 design. Of course, the amplification is fully protected from over current, over temperature and over voltage. This ensures that the loudspeakers are safe from harm during all conditions.
    The DVDI10 shares much of the same video technology as the DVD26. A high performance Shinwa SHD-2503 CD/DVD drive has been carefully modified by Primare prior to its integration with handpicked components in the innovative circuit topology. A wide range of video outputs ensures availability of the highest quality image your display device supports.The HDMI output features scaling up to 1080p.
    Full flexibility in system building is supported by three audio analog audio inputs, in addition to which a 3.5mm combined headphone output and line input jack plug is found at the front of the DVDI10. Two sets of analog outputs and the analog “sub†output are combined with a “tape out†for recording, and a “pre†output giving a variable-level output to a second preamplifier or power amplifier. The digital outputs allow you to connect to a digital surround processor. As the DVDI10 provides analogue to digital conversion, every source is available on the digital output.
    As any other Primare component the DVDI10 features RS232 control capability, data and IR inputs, a precondition for the integration in automated multi-room applications.
    To satisfy Primare's signature desire for operational simplicity, full remote operation is supported by the major function controls, conveniently mounted on the top panel, together with an interactive graphical display.
