We have a small batch of these in Cherry veneer at this very special price, new and sealed with two year warranty. [email]audiologica@btconnect.com[/email] [URL="http://www.audiologica.co.uk"]www.audiologica.co.uk[/URL] 01403 789226 Nominal Impedance 8 ohms Recommended Amplifiers 10 to 100 watts (150 watts + filtered) Frequency Response 80 Hz to 30 kHz Sensitivity 86 dB linear for 1 watt at 1 metre Bass/Midrange Driver 41/2†ProAc chassis, specially developed cone and dust cap. Tweeter 1†(25 mm) soft silk dome with neodymium magnet and radial fin cooling. Crossover Finest components on dedicated circuit board. Multistrand oxygenfree cable throughout. Split for optional bi-wiring and bi-amping. Dimensions 81/2†(216 mm) high 51/2†(140 mm) wide 6†(152 mm) deep with grille Weight 8 lb (3.6 kg) Mode Stand/Shelf/Wall mounting Grille Acoustically transparent crimplene A compact, quality satellite speaker that generates the whole frequency range except for low bass. Each speaker houses a recently designed 4 1/2 inch midrange/bass driver which utilises the same cone material as one of our most expensive, two-way stand mount designs, the much loved Response 1SC. Complementing this is a special one inch soft dome tweeter, which uses a neodymium magnet assembly with a radial fin cooling system to give maximum dispersion and power handling. The two drivers are harmonised through a high quality crossover network to produce a remarkably flat frequency response. The result is exceptionally accurate reproduction, in line with the very best mini-monitor performance. The Response Satellite is produced in a range of real wood veneers to complement other speaker components in a home theatre system.
