We have a small batch in black, mahogany and maple veneer only. [URL="http://www.audiologica.co.uk"]www.audiologica.co.uk[/URL] [email]audiologica@btconnect.com[/email] 01403 789 226 This centre channel speaker uses identical drive units to the Response Satellite with the addition of an extra bass/midrange driver and larger enclosure. The Response Satellite Centre is produced in a range of real wood veneers to complement other speaker components in a home theatre system. Nominal Impedance 8 ohms Recommended Amplifiers 10 to 200 watts (250 watts + filtered) Frequency Response 80 Hz to 30 kHz Sensitivity 86 dB linear for 1 watt at 1 metre Bass/Midrange Driver Drivers (2) 41/2†ProAc chassis, specially developed cone and dust cap. Tweeter 1†(25 mm) soft silk dome with neodymium magnet and radial fin cooling. Crossover Finest components on dedicated circuit board. Multistrand oxygenfree cable throughout. Split for optional bi-wiring and bi-amping. Dimensions 51/2†(140 mm) high 13†(330 mm) wide 6†(152 mm) deep with grille Weight 12 lb (5.6 kg) Mode Stand/Shelf/Wall mounting Grille Acoustically transparent crimplene
