Problems with Nero
Discussion in 'General Chat' started by Ludi, Jul 29, 2006.
  1. Ludi
    Ludi
    Jul 29, 2006
    Hi
    Im trying to burn a CD with audio and pictures using nero7 but keep getting the below error message, any ideas :confused:
    Unable to prepare data for recording: No space left on hard disk for temporary files (Internal error 1002)
    Ludi, Jul 29, 2006
  2. Ludi
    t1nt1n hifi collector
    Mar 5, 2006
    35
    Clear up some space on the drive it writes to (probably the c drive). It uses hard drive space to temporarily write data.
    t1nt1n, Jul 29, 2006
  3. Ludi
    lhatkins Dazed and Confused
    864
    Honiton, UK
    Yep sounds like a lack of space there dude, clear out some stuff, empty the recycle bin, clear out your c:\temp directory etc.
    It builds an image before it writes to the desk, there isn't enough space for it to do this.
    lhatkins, Jul 30, 2006
  4. Ludi
    Tenson Moderator
    Nov 12, 2003
    5,947
    If you have more than one drive or its partitioned in to two, then you might also be able to change the place it write its temporary files to in the settings of the program.
    Tenson, Jul 30, 2006
  5. Ludi
    la toilette Downright stupid
    Jan 21, 2005
    1,213
    Somerset
    I have Nero 5, but this is where you can change your temp dir;
    File - Preferences - Cache
    la toilette, Jul 30, 2006
