Processor suggestions please
Discussion in 'Hi-Fi and General Audio' started by rodrat, Feb 16, 2009.
  1. rodrat
    rodrat
    Dec 1, 2003
    295
    St Albans
    I have decided to buy a home cinema processor as I already have plenty of power amps. At the moment I am looking to spend no more than £600 either new or used. I would like to have a 'clean' two channel option so that I can use it as a straight pre amp for the two main speakers. Back in my more flush days I had a Bryston 1.7 which was very good but I doubt I could get one for that money.
    So far I have considered the Arcam 700 which I can get new for £600. I like the balanced connection option as most of the amps I have are pro and use balanced connections but this is more down to having plenty of balanced cables. Hdmi would also be nice but neither are deal breakers.
    Any other suggestions within budget or very close?
  2. rodrat
    Levi_501 Its in The Jeans...
    Nov 3, 2004
    453
    London
    Same problem mate !
    I am thinking of the new-ish Audiolab model.
    It is ment to be very basic, but very very good.
    Levi_501, Feb 16, 2009
  3. rodrat
    Petergc
    Feb 17, 2005
    95
    If you can find a Proceed AVP then I'd recommend that. It has an awesome analogue bypass, and true high end sound quality.Of course, an AVP2 is quite a bit better, but probably not available for your budget
    Petergc, Feb 17, 2009
  4. rodrat
    eisenach
    Sep 19, 2003
    249
    Tag Mclaren AV32Rs can be had for that sort of money, and they're still very good.
    £600 should easily get you a single (192 dac) processor with the 5.1 bypass.
    There's one on e-bay now, but it's seriously over-priced compared with what they've been making recently.
    eisenach, Feb 17, 2009
  5. rodrat
    Mr_Sukebe
    912
    London
    The Meridian 561 and 568 are well regarded, although the 568 will be hard to find at the price. Neither support HDMI unfortunately.
    Mr_Sukebe, Feb 17, 2009
