12x Black Rhodium locking banana's All in perfect condition. Really nice plugs with a one piece machined body. They're the locking types where you twist the outer body to firmly lock the plug in place. They also accept larger gauge(max 6mm diameter) cable unlike most of the other plugs I tried. The wire is secured either via soldering and/or using the dual grub screws. These normally cost something like £4 a piece if your daft enough to pay that. All twelve for £24 inc postage to the UK. ------------------------------------- QED Genesis bi-wire. 2x1.9m These are actually 2x 2m lengths but are little tatty on the ends so could do with terminating again. Once you've done that you'd have around 2x 1.9m. Stripping the cable back is easy but requires a bit of time and patience because of all the individually screened conductors. Great cable with a really chunky purposeful look and feel. I think the RRP is around £60 per meter or was when I bought this last year. So about £240 worth of cable, asking £70 inc postage within UK PS, just looking through my other bits and have no use for it so I'll throw in a QED silver spiral 1m stereo interconnect to whoever buys the QED Genesis cable. The cable just needs some RCA plugs sticking on the ends and you'll have a top interconnect for nothing Here's a shot of the Silver Spiral:
