Only a few months old £375 boxed with mannuals and Russ Andrews Yello power lead Delivery £15 UK main land Specifications Maximum Power Output 90wRMS into 8ohms (0.5% THD) 120wRMS into 4 ohms (0.5% THD) Maximum Output Current 11 Amps peak each channel Total Harmonic Distortion <0.05% (70w into 8ohms) Input Sensitivity (phono) 775mV Output Impedance 1.5 uH in parallel with 0.05ohms DC offset voltage less than 10mV Frequency Response 3Hz to 50kHz +0dB/-3dB Signal-to-Noise Ratio 110dB (20Hz-20kHz) ref. 70w RMS Dimensions 70mm x 321mm x 310mm
