Hi guys, Just moved into my new place, and the hifi has gone in the bedroom. Unfortunately, i had to get rid of the Rega Ela's, and in their place I have here some Tannoy 631 SE's... but really, they need to go on the wall. They are rear ported though, and seem to be relatively heavy, probably more than 6 kg each at a rough guess (I havent weighed them) so I am wondering whether its worth keeping them and try to mount them on the wall - they'd be going into a main wall as opposed to a partition wall. Is it worth it to keep them or should I look for something else... and if it is worth keeping them, what wall brackets would you recommend? They seem to sound alright, but they are just on my window sill at the moment, and thats not practical in the longer term. Cheers
