Re-spraying hifi equipment...
Discussion in 'DIY Discussion' started by skp574, Nov 17, 2004.
  1. skp574
    skp574
    Dec 4, 2003
    107
    Greenwich-sur-Thames
    Has anyone successfully tried re-spraying their hifi equipment. Reason for asking is I have a WHITE Sky+ box and would prefer it to be black. The top case is metallic whilst the front panel is plastic.
    Would anyone suggest a suitable spray paint. I'm not too worried about loosing the legends on the front panel but I could mask them if I can be bothered.
    Any advice greatly appreciated.
  2. skp574
    robert_cyrus
    685
    near the sea
    how about fablon ? then it can be reversed by peeling if off again. or changed to a new colour. b&q in the wallpaper section.
    robert_cyrus, Nov 18, 2004
  3. skp574
    michaelab desafinado
    6,403
    Lisbon, Portugal
    Robert - did you used to work for Blue Peter? :D
    michaelab, Nov 18, 2004
  4. skp574
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    I would look up repainting articles on computer modding sites, since the mix of materials (metal/plastic) is the same and the technique is the same. There are some good walkthroughs for dummies (including techniques for metallic paints).
    I used plastikote spraypaint from halfords for my hifi rack (although it's got a little beaten up by slabs of granite and housemoving, so it will get repainted after I buy a house), on top of spray-on primer. You will probably need to sand the existing finish to provide a key for the primer and paint to adhere to. After that spray primer and then paint each in several thin coats, letting each one dry for a while.
    I-S, Nov 18, 2004
  5. skp574
    zanash
    3,826
    Notts.
    or contact the makers of the unit and as for a black shell...and refit the innards.
    zanash, Nov 18, 2004
  6. skp574
    Sgt Rock
    873
    Robert, what is it with you and Fablon, is it the new M&*a or do you have shares in Fablon ;)
    Scott, I'm sure you can get spray paint that is fine with plastic, years back I did see some that was suitable for crash helmets.
    Sgt Rock, Nov 18, 2004
  7. skp574
    robert_cyrus
    685
    near the sea
    i'm just looking for an excuse to get some and use it myself.
    oooh, perhaps i can mod my pc case ?
    or my gf's dell laptop, she'd love that (not).
    oooh space theme
    [​IMG]
  8. skp574
    skp574
    Dec 4, 2003
    107
    Can't do that as it's not made in black. Hence the spraying
    skp574, Nov 18, 2004
  9. skp574
    stickman
    Jun 25, 2004
    199
    Just made some DIY seismic sinks and covered the pine "tray" with oak-effect Fablon - or "sticky-back plastic" for those of us born in the sixties. Looks quite good from my listening position, six foot away.
    stickman, Nov 19, 2004
