Recent rect. GRF and Tannoy Reds fun and games
Discussion in 'DIY Discussion' started by speedy.steve, Oct 16, 2011.
  1. speedy.steve
    speedy.steve
    Dec 3, 2005
    525
    Surrey/Hants/Berkshire borders
    I've been building a different dimension rect. GRF for that narrower room space...
    First I used Hornresp to model the back loaded horn section and get the volume / baffle (throat and mouth sizes right). Once suitably conforming with the original shape rect. Tannoy model it was time to cut wood. 21mm Scandi birch ply throughout of course.
    These are exactly the same volume at the others but are 45cm wide, 125cm tall and deeper by a bit.
    Here's some pics
    Basic plan
    [​IMG]
    Cut out - The front baffle really is the narrowest you can go...
    [​IMG]
    Under construction
    [​IMG]
    First cab up
    [​IMG]
    Recessed removable backs - allow access to crossover / tuning of the folded horn damping if needed. 24 screws fixing and gasket so no risk of resonance.
    [​IMG]
    Part finished - few more spray coats to go.
    [​IMG]
    In the room under test with HPD's loaded
    [​IMG]
    Brass panhead bolts or caphead?
    [​IMG]
    [​IMG]
    Full length vintage cloth grilles
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Geniune NOS Tannoy Reds badges
    [​IMG]
    [​IMG]
    Under listening tests with the Reds loaded and using a little 5W SET EL84 amp the sound easily filled my large lounge diner with great full Tannoy sound.
    The modelling worked - they sound just the same as the other Rect Tannoy cabs I have heard.
    I'm very happy with the resulting look / sound. Enjoyable project.
  2. speedy.steve
    felix part-time Horta
    Dec 13, 2003
    757
    dead
    Looks fantaastic, Steve. I really like the narrower/deeper cabinet.
    felix, Oct 16, 2011
  3. speedy.steve
    RobHolt Moderator
    Oct 24, 2004
    9
    Lovely work.
    Steve, have you thought about making the cabs available as a kit?
    Having seen your work first hand I think you should consider it, time and practicalities allowing of course.
    RobHolt, Oct 16, 2011
  4. speedy.steve
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Excellent work Steve, as always. I like the look of these.
    Dev, Oct 16, 2011
  5. speedy.steve
    speedy.steve
    Dec 3, 2005
    525
    Thx guys - it's always fun to model / design / build something a bit new (ok old concept / new shape for me).
    speedy.steve, Oct 17, 2011
  6. speedy.steve
    Jon
    Apr 14, 2009
    5
    Hi Steve
    Beautiful! How does it compare soundwise with your usual design.
    Also the vintage cloth does it make more of difference than the usual covering?
    All the best
    Jon
    Jon, Oct 26, 2011
  7. speedy.steve
    speedy.steve
    Dec 3, 2005
    525
    It's a while since I heard the normal format cabs but they are from memory very similar and have the GRF backloaded bass and of course the Tannoy front loaded sound.
    We did tests with the cloth and it was pretty transparent actually. Not as thick as some I have seen.
    speedy.steve, Oct 26, 2011
