recommend me some speaker cable please
Discussion in 'Hi-Fi and General Audio' started by humax66, May 29, 2007.
  1. humax66
    humax66
    May 10, 2007
    4
    Hi guys
    can anyone plese recommend me some speaker cable for some bookshelf speakers .is the stuff from richer sounds ok or maybe maplins . last time i was in richer sounds they had about 6 diffrent kinds of cable . what kind should i be looking at that wont break the bank
    Thanks all
  2. humax66
    6,766
    bucks
    Hi Humax
    Personally I'd go for any decent quality cable.
    I've used speaker cables costing no more than £5-£10 per metre with setups up to £10k.
    Some people swear by expensive stuff, but my experience has taught me that it's a waste of my own money so I don't spend money here.
    To be as impartial as I can, perhaps a good hifi shop can lend you a few runs of different stuff to try at home.
    bottleneck, May 29, 2007
  3. humax66
    joel Shaman of Signals
    Jun 21, 2003
    1,650
    I use good quality mains cable (the orange stuff for outdoor use from home centers comes highly recommended). HTH.
    joel, May 29, 2007
  4. humax66
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    anything decently thick and solid core, i use a cat5 cable twisted together on my 2nd set up.
    sq225917, May 30, 2007
  5. humax66
    humax66
    May 10, 2007
    4
    thank you for all the help guys
    humax66, May 30, 2007
  6. humax66
    zanash
    3,826
    Notts.
    try 15-20amp twin and earth....its a pig to work but sound rather nice ....if you like it you can then spend more dosh on the hifi versions ....
    check out tnt audio for the diy recipes there are some good ones.
    zanash, May 30, 2007
  7. humax66
    nando nando
    Jun 1, 2006
    4,017
    london
    hi, try black rhodium, regards nando.
    nando, Jun 1, 2007
  8. humax66
    Levi_501 Its in The Jeans...
    Nov 3, 2004
    453
    London
    I think Chord is very hard to beat.
    I have used it for years never had any problems with it.
    Levi_501, Jun 4, 2007
  9. humax66
    anubisgrau
    Mar 24, 2006
    663
    anyone tried anti-cables?
    anubisgrau, Jun 4, 2007
  10. humax66
    Neil
    Jun 21, 2003
    631
    Scotland
    Anti's - to me sounded like DNM Reson - clean, tight bass - but I thought just lacking a little something. I've heard fair differences between speaker cables but never had a 'night and day / better than new speakers' moment. The best cable i heard was WM / Coherent Connioseur (?spelling?) cable, I can't afford the 4m pair I currently need though!
    I'd suggest that you try Kimber 4PR (cut and stripped, don't bother with termination) from - Gasp, ducks to avoid incoming - Russ Andrews. I've always liked the Kimber house sound and the 4PR is a great entry level cable. As RA has a 60 day return guarantee you can't really lose - you could order some 4TC to listen to as its a great all rounder, but perhaps a tad expensive.
    Neil, Jun 4, 2007
