I have a couple of problems with my RB600 arm, neither affect play but none the less probably should be sorted out. Firstly the arm drops at the speed of gravity rather than the slow/damped speed it should. Its not a major issue I just need to lower it slowly myself. Second issue (again with the arm lift) it doesn't lift the stylus high enough to clear the record, again I have a work around, I've added a shim of waxed card cut to shape so all is fine. I notice I can buy a new arm lift from ebay for £20, should I just replace the old one - problem solved, or should I get the whole arm or deck serviced as there are probably other issues too? Or just leave it as is because in use its no big deal?
