Rega Fono??
Discussion in 'Hi-Fi and General Audio' started by dos, Jan 19, 2008.
  1. dos
    dos
    Aug 28, 2007
    123
    Am trying a rega fono (phono stage) on my planar 3 (dynavector 10x5). My amp (rotel ra-04) has a phono stage but have been told that a separate phono stage will improve things...
    Am getting very :mad: frustrated trying to see the difference. I keep thinking there is and then i don't. The main difference (i think) is that the sound is a little bit brighter / more forward perhaps.
    Should there be much of a difference? I've read the argument and agree but maybe a £150 phono stage just doesn't do it.
    Any opinions gratefully recieved :)
    dos, Jan 19, 2008
  2. dos
    Andy registered grazer
    May 7, 2006
    322
    London.
    I've heard a few times the built in phono stages in Rotel amps are rather good, at the price level. You'll probably have to spend a little more to better it.
    Andy, Jan 19, 2008
  3. dos
    dos
    Aug 28, 2007
    123
    That's what i figure...i think i'm beating myself up trying to hear a little difference :confused:
    dos, Jan 19, 2008
  4. dos
    dos
    Aug 28, 2007
    123
    what phono amp would you recommend? Or should i stick to the amp?
    dos, Jan 19, 2008
  5. dos
    Levi_501 Its in The Jeans...
    Nov 3, 2004
    453
    London
    If you hear a difference, great you do not, you do not.
    I would not loose sleep over it.
    EAR 834P is what most people lust after. But I think you can pick up some bargins in ebay, Michelle, Tome Evans etc.
    Levi_501, Jan 19, 2008
  6. dos
    Zylog
    Apr 3, 2005
    27
    Essex UK
    I also use a Rega T/T but the P3 with elys II and Rega fono amp.
    It dose what I want it to do; it plays music!!!!
    Do you want to hear the difference or enjoy the music, if you are thoroughly enjoying your music who cares if there is a very very small difference between the stages.
    Play the discs and immerse you rself in the music.
    Zylog, Jan 19, 2008
  7. dos
    RobHolt Moderator
    Oct 24, 2004
    9
    Why automatically assume that a built in stage is inferior to one in an external box?
    Rotel have been building amps for decades and know how to design a competent phono stage.
    Enjoy it and stop worrying.
    RobHolt, Jan 20, 2008
  8. dos
    Andy 831
    Jan 19, 2006
    389
    Out on a wild and windy moor
    As rob says, and save a few quid as well by not buying any new kit.
    Andy 831, Jan 20, 2008
  9. dos
    dos
    Aug 28, 2007
    123
    That settles it - it's going back! Thnks for the honest feedback.. i shall spend the money on records!
    dos, Jan 20, 2008
  10. dos
    rollo
    Nov 30, 2006
    339
    N.Y. U.S.A.
    Agreed. You will have to spend more to ouperform the Rotel. Dynavector makes a separate Phono Stage that will mate with your Cart. pretty well. Check it out.
    rollo
    rollo, Jan 20, 2008
