Rel Stampede in oak real wood veneer, good condition and excellent working order. Its a cracking musical sub that can also slam with movies but I need a power amp. Comes with remote and manual and power lead, dont have the box but can package well. Will swap for a Quad 606/2 or am open to suggestions why. Some bumf below and pics on request. Full action remote microprocessor control of all set-up parameters Large, blue front-firing LED display True 100W (continuous) discrete, direct-coupled MOSFET amplifier Downward-firing long-throw 200mm (8â€Â) steel chassis driver Improved ABC® filtering circuit calibrated in single Hz steps from 16 to 99 Variable Slam/Depth control –9dB to +9dB at 80Hz High quality, gas-tight Neutrik Speakon input (high level) High quality, panel-mounted single phono input (low level) 5-12V DC trigger Parental control: front control panel may be locked Totally discrete input circuitry for high and low level inputs Separate volume controls for high and low-level adjustment Simultaneous connection of high and low level sources Set-Safe® audibly transparent driver protection Double-sided glass-fibre board with plated-through holes IEC power input socket and switch - no captive leads for installation flexibility Finished in 30mm MDF in Brittex Black and Silver and balanced Black Ash, Maple, Cherry, Walnut, Light oak and Rosenut real wood veneers Hand-built in Great Britain, three-year worldwide warranty
