Repairs: Sonic-T
Discussion in 'DIY Discussion' started by lhatkins, Jan 12, 2006.
  1. lhatkins
    lhatkins Dazed and Confused
    864
    Honiton, UK
    Hi
    My sonicT has developed a problem with its volume control, I remember someone saying they were a bit cheap. Can someone suggest how I go about replacing it? Is there a direct replacement part? possiblely one that will last more than 6 months a?
    Thanks.
  2. lhatkins
    zanash
    3,826
    Notts.
    If you pm me .....I've a couple waiting to be modded so i can drop a vol pot for you.
    I would suggest fitting a better one, and reap big rewards over the nasty thing that came fitted with mine.
    zanash, Jan 12, 2006
  3. lhatkins
    864
    Honiton, UK
    PM'ed, and thanks, ya agree an upgraded pot would be good, but for the mo a direct replacement will get it back into service again, then I'll look at an upgrade for it! :) Cheers
    lhatkins, Jan 13, 2006
