I now have all the software, cabling and mic equipment to take my own room measurements and thought I would present the results as I went along. Here is the initial frequency plot. As you can see relative to the midband the treble is raised and the bass is depressed - which does a lot to explain the observed brightness of the system. Next step is to make the adjustments to the crossover and remeasure. Crossover points are 380 hz and 3800 hz which matches almost exactly with the observed frequency plot.
