Ok, I'm after a good sat and sub speaker setup. Needs to be reasonable for 2 channel audio. My av needs are modest. Don't want to spend £500 each on Spendor SR5 (they're 1000USD per pair once shipped to the USA). Amp wise I'll stick with my NAP110 and NAC62 for the sats. May be go valve later. Sub will be self-powered or powered by a ss amp. I'll sell my Dyn 52 to partially fund the newer kit. I have a pair of jr149 which I may try as sats. What do people do with splitting the signal ? The sats will work a lot better if they don't have to contend with <120Hz. I know theres a passive and active option. Another option is to go for dedicated sats, designed for the job. I could conceivably go for B&W M1,as used in the MT10,20,30 series, but not use their subs and build my own sealed push pull unit. Thanks
