Hi all, I wonder if I could get your opinion on something! I'm a little stuck and you may recognise the problem. I have some valve monoblock amps with a set of valves in them. The valves are KT90's. There are 8 in each amp. I have an engineer looking at them at the moment (for a checkup). One of the amps will not sustain a stable bias (after 1 hours warm up). The other one will. With no music signal input the measurements are jumping all over the place at maximum 30mv + or - on the bias of 75mv. I.e. not stable. He's checked all the resistors etc. but doesn't have a valve checker. This guy is very clued up with electronics (it's his business). Does this sound like the valves are on their way out? The previous owner (6 months ago) told me that the valves were new. He's a really top pro so be as technical as you like and I'll pass on the info. Any ideas? Many Thanks, Tim
