I listened to these on two occasions, powered by both valve and solid state amps, and I like them. Very much. Bit pricey, but I've almost talked myself around that... I've just one concern. The room that they'll be used in. The auditions I've had have been in larger rooms than the one I'd use the speakers in - our living room is about 16'x12'. I'm concerned that the bass will be be overbearing. I've read (dangerous things, reviews!) that the Hyperions are quite sensitive to positioning and proximity to walls. There is room on the 12' wall to position the speakers far enough away from the sides to get around this, but I [i]may[/i] then end up with the speakers too close together. Any thoughts? Has anyone had similar problems and resolved them? Presumably this isn't an issue restricted to these speakers. A home audition would be perfect, but not very easy to arrange given the weight of these beasties! If the HPS-928s are going to be hopelessly unsuitable, what alternatives do I have? Our amp is a Gryphon Callisto, sources are an AVI S2000MC Reference CD player and a Kuzma Stabi/Stogi Reference turntable/arm combo. We'll be doing something AV with the TV and DVD in due course, but we've not decided what yet! TIA, Graham
