Show us Your Kit!
Discussion in 'Hi-Fi and General Audio' started by Terry, Jun 19, 2003.
  1. Terry
    Alco
    Nov 30, 2003
    94
    Holland
    Nothing new here... just tried to make some sort of arty sideview systempic. :D
    [​IMG]
    Squeezebox Touch, Metrum Acoustics DAC, Naim Nait 5i and Diapason Micra mk3 on Target HR60 stand.
    Alco, Feb 20, 2011
  2. Terry
    Batty Registered Insane
    Aug 9, 2010
    30
    Adelaide SA
    Don't know about the live, but the non live is OK for movies but less than mediochre for audio, so I got an SB touch.
    Batty, Feb 23, 2011
  3. Terry
    Gromit Buffet-blower
    May 4, 2004
    345
    Darkest Lincs
    Updated as of Feb '11...
    [​IMG]
    Garrard 401 (early) in Russ Collinson plinth.
    SME 3009 II (early - non-improved, metal knife edge) with AO Cardas re-wire.
    Denon DL110 in Sumiko HS12 headshell.
    Dynavector P75 phonostage.
    MacBook - M2Tech HiFace - hot-rodded CA840C CD player (used as dac)
    Inca Tech Claymore
    Royd Merlins on Something Solid stands - Talk 3 speaker cables.
    Gromit, Feb 28, 2011
  4. Terry
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Heavy! :)
    Dev, Mar 1, 2011
  5. Terry
    May 4, 2004
    345
    Darkest Lincs
    A few more pics...
    [​IMG]
    [​IMG]
    [​IMG]
    Gromit, Mar 2, 2011
  6. Terry
    Labarum
    Oct 18, 2008
    492
    The loathsome chore - redecoration; but it has given me the opportunity to tidy up the AV.
    So:
    [​IMG]
    That's it. Minimalism!
    Open the door:
    [​IMG]
    The Quad 405 is facing back with its heat sink poking out of the back of the Ikea box.
    Above you can see the Caiman DAC which takes optical in from the TV, RCA S/PDIF from the Squeezebox which sits in front of the TV, and there is a USB cable loose at the back of the TV in case I want to run the laptop straight into the DAC. There is is a long HDMI cable running along the skirting board. I pull it out from under the sofa and plug the laptop in to see BBC iPlayer content.
    That will do for now. In the longer term I will put a small format PC on the back of the TV or in the Ikea box and use Remote Desktop to control it.
    And looking down the room at my beautiful redecoration and the new carpet:
    [​IMG]
    The curtains have yet to be hung, but we do have shutters.
    edit: Speakers moved.
    [​IMG]
    This puts the power amp heat sink 1cm from the night store heater, so something will have to change before next winter!
    Labarum, Mar 3, 2011
  7. Terry
    James_1D
    Jul 28, 2010
    68
    Living Voice, Moon and Abbeyroad Cables....
    [​IMG]
    James_1D, Mar 10, 2011
  8. Terry
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Nice system James. I really enjoyed the LV speakers at the show last Sunday.
    Brian, again nice, and tidy. After seeing the first picture I thought the TV was sitting on a sub.
    Dev, Mar 10, 2011
  9. Terry
    jimdgoulding Manufacturer
    Jul 26, 2009
    53
    System overview
    Amplifier: speakers are active (internally bi-amped). Preamplifier: ARC LS7 tube line stage (JAN/Philips 6922's). Speakers: MTM 2 way Meridian M20's with after market stands to raise their height to ear level. Sources: CD Player/DAC: Sony DVD transport/Bel Canto 1.1 DAC. Turntable/Phono Stage: Nottingham Horizon/Expressimo modified Rega arm/Grado Sonata Reference; Monolithic Sound phono pre. Other Source(s): Micro Seiki BL91 turntable/Premier MMT arm/ first generation Koetsu Black; Marcof battery powered step up MC transformer. Other Accessories/Room/Misc.: Speaker Cables/Interconnects: Morrow MA3 IC's; 1.5m KCI Pegasus dig cable. Other (Power Conditioner, Racks etc.): PI Audio UberBUSS. Tweaks: Custom made felt tweeter surrounds to my speaker cabinet width dba diffractionbegone.com, my small enterprise. Room Size (LxWxH): 15' x 12' x 8'. Room Comments/Treatments: Dedicated live-end/diffused-end room with speaker placement and seat composing an equilateral triangle well away from room boundaries; 1 GIK panel on side walls adjacent to speaker position. Music Preferences and Comments: Music Used (Genre/Selections): Jazz; classical; r&r; r&b; ethnic classical and world folk. System Goals/Comments: Get the purest experience of the event I can with minimal system or room artifacts. System Strengths: Transparent to what's going on. Three dimensional soundstage and imagery. Time and phase integrity via active crossovers. Warm and detailed sound. System Weaknesses: None all things considered. URL Link: http://www.diffractionbegone.com.
    jimdgoulding, Mar 13, 2011
  10. Terry
    plastico
    Mar 13, 2011
    3
    Sudbury, Ontario, Canada
    Hello everyone. I just joined and I would like to share my kit, as it were.
    Bryston 4B ST with Gut Wire power cable
    Grant Fidelity 307 Phono/Pre with Psavane tubes
    Rega P3 ,on a wall stand with 2 1/2 inch maple board and a 3/4 inch granite slab with Herbie Audio Lab Tenderfeet, with a sheet of Dynamat underneath the plinth. Groovetracer Subplatter and acrylic platter and Michell counterweight rounds off the table.
    Dynavector 10x5 cartridge.:D
    Paradigm Studio 80 v2 speakers with Van Damme speaker cables, with soon to be Diffraction Be Gone speaker diffusors.
    All interconnects have Eichman Bullet Plugs . :) Cheers, Plastico
    plastico, Mar 14, 2011
  11. Terry
    James_1D
    Jul 28, 2010
    68
    Ok, quality is naff, as I used my Imac....but put some vids up on youtube of my system.....
    James_1D, Mar 20, 2011
  12. Terry
    Zerowaf
    Mar 25, 2011
    3
    Another New Kid on the Block...
    Hello all,
    New to ZG and new to the higher end of audio as well. Have only just begun on my journey, with virtually all of my gear representing very fortunate second hand 'scores'. For example, I picked up my Sony CDP S-7000 for $5--it's basically in mint condition!
    Pics of gear attached.
    Have recently replaced the monster cable stuff with my own DIY cables--a significant improvement!
    Cheers,
    Z
    2-Channel Audio
    - Magnepan MG12-QR
    - Sony DVP S-7000
    - EAD DSP-1000
    - Sonic Frontiers SL1 Signature Series
    - Sonic Frontiers SFS-80
    - Decent interconnects/cables that came with tube gear/DAC
    HT
    - Onkyo TX-NR807
    - PS3
    - Optoma HD200-LV
    - 88" Elite fixed projector screen
    - Paradigm in-wall speakers
    - A cheap, second hand paradigm subwoofer (CT series, I think)
    Zerowaf, Mar 26, 2011
  13. Terry
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Zerowaf (nice name:)) welcome to the forum. Hope you like it here.
    Dev, Mar 26, 2011
  14. Terry
    Alco
    Nov 30, 2003
    94
    Holland
    Wow... That's one impressive looking system and room you've got there Zerowaf! :)
    My humble (in size and price) system:
    [​IMG]
    [​IMG]
    [​IMG]
    Alco, Apr 4, 2011
  15. Terry
    5,139
    Manchester
    I have recently rewired my system when I purchased the Yamaha amp for £40 as my Azure 640a broke.
    [​IMG]
    My system hasn't changed that much since I registered here seven years ago:-
    • Yamaha AX 392
    • Rotel 870BX (use this for input selection, headphone output and phono stage)
    • Project Debut II
    • Marantz CD 6000 OSE LE
    • Wharfedale Diamond 9.1
    • Panasonic Blueray player
    • Goodmans PVR
    • Accustic Solutions FM/DAB
    • Grado SR60i headphones
    • M Audio 24/96 Audiophine sound card
    amazingtrade, Apr 16, 2011
  16. Terry
    RobHolt Moderator
    Oct 24, 2004
    Awesome speaker stands :)
    Aren't they a bit high though?
    RobHolt, Apr 16, 2011
  17. Terry
    Chris Davies
    Jun 16, 2009
    218
    [​IMG]
    That's mine so far starting a diy turntable build soon though.
    Chris Davies, Apr 16, 2011
  18. Terry
    5,139
    Manchester
    The reason the speakers are so high (100cm) is that my listening position is my tall bed. The tweeters are aligned to my ears. I haven't got space for stands, I am self employed so I keep all my receipts and tax returns in those drawers and then some.
    amazingtrade, Apr 17, 2011
  19. Terry
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    sq225917, Apr 17, 2011
  20. Terry
    nando nando
    Jun 1, 2006
    4,017
    london
    quote
    hi chris, are the spkrs BERKLEY'S
    nando, Apr 17, 2011
