Shure V15III Query...
Discussion in 'Hi-Fi and General Audio' started by danza, Apr 26, 2004.
  1. danza
    danza
    Feb 29, 2004
    33
    Hi all,
    I'm seriously considering buying the above mentioned cart 2nd hand off ebay, but I have a few questions...
    1. Are there any negative traits that these carts posess, such as do they fall to bits?
    2. The genuine Shure styli are too damn expensive, so I was thinking, are the Swiss copies that you can get through Mantra Audio any cop (only about £25)?
    3. How old are they, and do they deteriorate significantly with age?
    4. Is it likely to better my Goldring G1012, or indeed even a G1042?
    Thanks for reading,
    Danza.
    danza, Apr 26, 2004
  2. danza
    Dec 5, 2003
    1,928
    East Midlands
    Danza,
    If you search the archives you will find somewhere info on how to go direct to Shure and get genuine Shure replacement styli for $50 under their stylus replacement scheme. For the V15III this includes the VN35MR stylus which retails for over 100 quid and allegedly takes this cart to a similar level to the current V15VxMR incarnation.
    Hope this helps.
    Uncle Ants, Apr 26, 2004
