...so I decided to take the lid off my cd transport and have a look inside, with a view to some modifications. The equipment in question is a Cambridge Audio discmagic 1, very much a budget component in that I bought it second hand for less than £90, but it is the cheapest way I've seen yet to get a transport with an AES/EBU digital output which is apparently the best digital interface for use with a DAC. [IMG]http://img197.echo.cx/img197/6062/discmagic7qv.jpg[/IMG] There are some other things which to my relatively untrained eyes seem reasonable design features, namely separate 'custom power' supplies (albeit non-toroidal) for the digital output section and the servo & control board, the copper shielding around the output board. I think the cd mechanism itself is a Sony. Theres an optical clock input, and a DDD interface input, I have no idea what the latter is for and since my DAC (modded M-Audio superdac) doesn't have its own clock or clock output, then I'm presuming the former is of no practical use to me? I had considered getting a Pioneer DVD-575 as a transport as come September I'll probably want to play DVDs as well, but I reckon the Cambridge I have already has some potential anyway, and with AES/EBU output would be a better transport than the Pioneer which only has co-axial. The mods I had planned to do myself: - Damp the players casework with Dynamat - Add additional copper shielding, between the two power supplies and in the bottom of the player. - Damp the clock and surrounding areas of PCB with blue-tak (I have a problem here though in that I don't recognise any component as being the clock, I am looking for a small silver 'can', but theres nothing like that on the PCB, what else could it look like? I presume its likely to be on the digital output board rather than the other PCBs) Then I had hoped to get a Trichord clock and clock PSU fitted. However I was wondering given the DIY expertise present here what else would be worthwhile? Replacing the large capacitors on the servo board? Better internal wiring? I have little to no skills with a soldering iron but I do want to learn since DIY seems to offer great sound per pound, and I feel this could present an interesting budget project which could yield some fairly good results - I have 4 months off from uni this summer so time is not an issue, only the skills which I figure I'll have plenty of time to learn.
