Solid State amps with 'presence'
Discussion in 'Hi-Fi and General Audio' started by McShads, Jul 9, 2008.
  1. McShads
    Class A
    Jul 1, 2004
    334
    UK
    POWERRRRRRRRRRRRRRRRRRRRRR :p
    Class A, Jul 16, 2008
    #41
  2. McShads
    Purite Audio Purite Audio
    Nov 25, 2006
    1,250
    You know what they save Dave, if the first watt is crap !
    Purite Audio, Jul 16, 2008
    #42
  3. McShads
    Nomoretweaks Tourist on tilt
    Dec 9, 2004
    265
    Richmond
    Want to try my ASR Emitter? It is within your budget. It does have presence :) Although to be completely honest, I doubt if you could find a real tube-like presence in a SS amp. Emitter might be as good as it gets outside tubes.
    A good tube preamp may add some presence to a SS power amp though, it might be an option.
    Nomoretweaks, Jul 16, 2008
    #43
  4. McShads
    banpe2006
    May 2, 2006
    359
    West Mids
    what are those big sugden monos and pre called? theyre the masterclass range, but theres a stereo power called the AA ..and a set of monoblocks - are the monos and the AA stereo the same amp? or a different model altogether
    banpe2006, Jul 17, 2008
    #44
  5. McShads
    spev
    Jun 13, 2005
    88
    LFD - really seriously nice amps.
    spev, Jul 17, 2008
    #45
  6. McShads
    Dec 5, 2003
    1,928
    East Midlands
    and if the first watt is excellent ... and so are the following 400 watts :) ??
    Uncle Ants, Jul 17, 2008
    #46
  7. McShads
    Nov 25, 2006
    1,250
    If you use inefficient speakers you need the current, which of course begs the question why would anyone buy inefficient speakers in the first place.
    Purite Audio, Jul 17, 2008
    #47
  8. McShads
    Dec 5, 2003
    1,928
    East Midlands
    Because they might sound good maybe.
    #48
  9. McShads
    Nov 25, 2006
    1,250
    Perhaps! I tried quite a few, diamond tweeters ceramic drivers, nothing sounds as real as really good compression drivers and horns!
    They are a touch on the large side though.Keith.
    #49
  10. McShads
    Dec 5, 2003
    1,928
    East Midlands
    Which would be the other reason.
    #50
  11. McShads
    Nov 25, 2006
    1,250
    After a few years you hardly notice them!
    #51
  12. McShads
    D Louth 77
    Jun 13, 2008
    377
    I Guys and Gals
    How the dulcets behave will depend on the size of the room,i use a pair in a tiny room with great results. I have used a minimum power rating of 18 watts with good results (depending on Genre of music). However they will need and even in my small room do respond well to more power(must be quality). A Bat Vk300se intergrated was very good as was aConsonance cyber 100 300b amp,with T J Meshplate valves . Normally i use a Bat pre and a Music Reference rm 200(100 watts kt66)
    However recently a friend has lent me his pre power(only 5 watts),and this tiny amp has opened my eyes and ears .It blows away almost all of my kit in purity of sound,open-ness and detail. It has an amazing amount of current despite its size and power rating(works because this is a postage size box room in the house ,it would not work with the dulcets in a bigger room).
    But to answer the first question is there a solid state amp/hybrid that is as good as valves simple imho answer is NO. I have heard some get close but none have beaten valves comprehensively .Especially in the areas of dynamics,speed,clarity,naturalness,dimensionality.
    I would look for a 35/50 watt class a amp. Maybe using 845 valves or a kt 66/88 or even el34/5881. One amp that would work well in a smallish room would be an Audio Innovations series 500 (early version,with the three speaker taps4/8/16 ohm and black/dark browny black) and re-valve it with Tung-sol reissue 5881 valves,doesn't need to be re-biased,though i would get an engineer to check it out) .One with a border patrol power supply would also be very good too. If your room is big and you like Metal and Dance Music this may not be powerful enough.
    The Dulcets respond to Power but also need quality. I have also had great results with Audio Innovations s1000 mk 3 amps re-valved with Tung-sol 5881 valves and an Ear 864 pre-amp using Audience Rca-Rca cables and xlo type 6 speaker cable
    Regards D Louth
    D Louth 77, Jul 17, 2008
    #52
  13. McShads
    McShads
    Jun 8, 2008
    59
    What amps did you audition?
    McShads, Jul 20, 2008
    #53
  14. McShads
    McShads
    Jun 8, 2008
    59
    There are a couple of dealers advertising ITs for £2k at the mo.[/QUOTE]
    Could you let me know who is advertising the IT's, thanks.
    #54
  15. McShads
    McShads
    Jun 8, 2008
    59
    #55
  16. McShads
    McShads
    Jun 8, 2008
    59
    I have considered both these, how did they compare/contast?
    #56
  17. McShads
    McShads
    Jun 8, 2008
    59
    By the way sorry for my delay in responding, my email update for this thread appears to have stopped working and I had assumed the thread had died. Glad it hasn't!
    #57
  18. McShads
    McShads
    Jun 8, 2008
    59
    Do you know of any good 845 amps?
    #58
  19. McShads
    lbr monkey boy
    Jul 13, 2004
    837
    In a happy place
    Hi mcshads, i listened, all at home, to border patrol, audio note and allnic. I bought the allnic. All single ended though - i have up on solid state a while ago (although i still have a secret interest in battery powered kit :))
    lbr, Jul 20, 2008
    #59
  20. McShads
    Dec 9, 2004
    265
    Richmond
    Nomoretweaks, Jul 20, 2008
    #60
